Here are the pics of the repairs i made to my compressor made a new tail pipe,modify the new stock muffler i bought,the old one came apart.Also made a new guard for the front of the motor from some perferated metal and hanger stock from work.I,m thinking of packing the conduit pc in front of the muffler with a little steel wool to quiet it down.Anybody ever try this?
Thread: Minor repairs to my IR
03-07-2009, 07:30 AM #1
BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
HT/PWR-MAX1250 PLASMA
03-07-2009, 07:57 AM #2
I bet that sucker is loud.
Just a thought, could you use a muffler from a small car?Tim Beeker,
T-N-J Industries
(my side bussiness)
Esab 450i with wire feeder
HH135 mig
Miller aircrafter 330 - sold
Marathon 315mm coldsaw
table saw
Dewalt cut off saw
Sand blast cabinet
lots of hand grinders
Harris torch
beer fridge
03-07-2009, 08:32 AM #3
I just had the whole pipe off the studs in the motor are small and one was in tuff shape the weight is the issue i,m going to add a brace off the bottom of the conduit pc i added and pack little steel wool to muffle in down a tad more.In one of the pics you can see a little bracket off the cylinder head going to bolt there and weld to conduit and drill holes/heat sink to prevent a little less heat tranfer to the head off the muffler assemble
BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
03-08-2009, 04:30 AM #4
- Sep 2006
- Wichita Falls, Tx
- 177
the steel wool might catch on fire from the heat, get some fiberglass muffler insulation and pack it with that. dirt bike wrap will work and is cheap. use something like this
http://www.jcwhitney.com/webapp/wcs/...atalogId=10111
03-08-2009, 04:33 AM #5
- Sep 2006
- Wichita Falls, Tx
- 177
some reason my first post did not work
but I was saying that steel wool is flammable, and it might catch on fire from the heat. I would recommend some muffler fiber glass. dirt bike muffler wrap is cheap. here is an example http://www.jcwhitney.com/webapp/wcs/...atalogId=10111
03-08-2009, 04:29 PM #6
#3 steel wool
No good just tried it made the muffler real hot and when i shut it down a little bit inside caught fire so scratch that idea.
BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
03-08-2009, 07:05 PM #7
RETIRED desk jockey.
Miller Syncrowave 250.
03-08-2009, 09:10 PM #8
- Jun 2004
- nj
- 204
I'd second a muffler from a small car.
If not, Several options.
Among them:
Kaowool (mineral fiber insulation) or fibreglas (not as heat resistant, but ok) packed around the inside. NOT stuffed in, as it will restrict flow.
Longer large pipe with some washers welded in spaced nonuniformly. Spacing about one pipe diameter apart with the hole a little larger than the inlet pipe size.
A half baffle (like used on a stock Harley muffler). Perforate a hunk of sheet metal with 1/4" holes spaced on maybe 1/2 to 5/8 centers. Cut to width the inside diameter of the tube and length so that the total area of the holes is maybe 1/5 times the cross section of the inlet pipe. Bend the ends one up and one down to make a 'Z' shape and trim the bent ends to semicircles that fit in the tube.
Muffler design is an art and science. You can mess with the thing for a LONG time to get what you want. You might also look at what Honda (and a few others) put on their little portable 'silent' generators. They really are darn near silent.
03-09-2009, 07:07 PM #9
- Sep 2006
- Wichita Falls, Tx
- 177
Sorry tried to warn you, but when I tried to post that morning, There was some filter that though I was a spammer since I had a link in my post. The Admin had to go back and "release" my original post. But it looks like you found out the hard way. And just a FYI for peoples emergency survival pack, keep steep wool in there because it is very easy to ignite. I only takes one spark and it up in flames. It is more flammable than the dryer lint.
I don't remember whether it was on a snowmobile or dirt bike, but it ignited quickly and turned into lava spitting out the exhaust.
