There is a used Miller 200LE with 660 hours on it for sale locally. It has been converted to propane but don't have any other infomation about it.
Is this a lot of hours? How long do they last? What should I look for in checking it out?
Living in Florida, it seems like a good idea to have a generator on hand anyway, this would kill 2 birds with one stone.
Any help would be appreciated.
Rush
Miller CP-200 w/3045 spoolgun
Results 1 to 10 of 11
08-14-2007, 06:11 PM #1
- Aug 2007
- Tampa, Florida
- 10
Used Generator/Welder model AEA-200LE
08-14-2007, 06:17 PM #2
- Aug 2007
- New Orleans, LA
- 161
I have over 450 hours on my lincoln and it's not a year old yet. I've put over 600 on a trailblazer in less than 6 months. It was also being used as a generator at the time as well, so not all was welding. Actually it's just getting broke in good.
Westinghouse: 400+ amp AC
ThermalArc Handy wirefeeder
1 Harris, 3 Victor O/A rigs
Arcair gouger
08-14-2007, 06:31 PM #3
- Jul 2007
- Batavia, NY
- 159
Rush,
If you can provide a serial number I can tell you how old the machine is.
How much are they asking for it? If it is an AEAD 200LE it is a pretty old machine. What I would want to know (especially since it has only 660 hours on it) is when was the last time it was run. I would wonder what kind of shape the engine was in. The fields may need to be flashed.
Back in it's day the AEAD 200LE was a whale of a machine. Unmatched arc characteristics in it's field. Not mutch of a generator 5KVA I think.Rich Ferguson
Sales Technician
Jackson Welding Supply Co.
www.jacksonweldingsupply.com
08-15-2007, 04:42 PM #4
250 hours is almost the same as 3,000 miles on a car. essentially it hasnt even been broke in very good. i have a legend ae/ad 200le. built in '88 and have almost 6,000 hours on it. lots of gas and oil later it still strikes an arc better than the newer ones do(in my opinion).
08-15-2007, 08:36 PM #5
- Aug 2007
- Tampa, Florida
- 10
Miller Roughneck 2E
In my search I also found locally a Miller Roughneck 2E, serial number JF848371. The specs are almost the same as the 200LE, but the motor is a single cylinder Tecumseh, can't be as good.
2E: 200A@25volts @ 100% and 7KVA genertor
200LE: 225A@25volt @100% and 5KVA generator
I think this is a low hours unit, but no hour meter to tell. He hasn't started it in 10 years.
The guy wants $650 for it with 100 feet of stinger lead and 30 feet of ground.
What do you think? More generator welding less amps.
08-16-2007, 07:59 PM #6
- Jul 2007
- Batavia, NY
- 159
The Roughneck is a 1985 machine.
The Roughneck is no where near the class of the AEAD 200LE. We are talking Roughneck = VW Rabbit AEAD 200LE = 1968 Chevy Camaro all tricked out.
I know the amperage rating is similar, but arc characteristics it's not even close. Were you able to get the S/N off the AEAD?Rich Ferguson
Sales Technician
08-16-2007, 09:33 PM #7
- Aug 2007
- Tampa, Florida
- 10
I haven't been able to meet the guy yet with the 200LE. I hope to see him and the machine on Friday.
11-27-2008, 08:13 PM #8
- Nov 2008
- 1
miller roughneck
i have a machine with a broken engine is a miller roughneck 2E, i will like to know where i could find a new engine for it, thanks
11-28-2008, 11:43 AM #9
- Sep 2005
- 4,248
For 650 I wouldnt blink, especially with some lead, take it before he changes his mind.
11-28-2008, 12:17 PM #10
- Oct 2007
- 2,949
Miller AEAD 200
JWSRP: Did that machine have the "current jacks" in the front? Are they like TWECO? Heck, for $650, it would be worth it, even if the engine needed rebuilt or replaced.
I guess you'll be able to tell more when he gets the serial number for you. Another member showed pictures of an SA-200G Lincoln he got for FREE, took it home, fixed it up, as good as new!
"Bonne journe'e mes amis"
