Results 1 to 10 of 12
    Mar 2009
    25
    Default welding table... just tacking?
    Hi, new guy to welding here, just got started with gas welding (oxy/ace) and I'm discovering that i need to build a few tools in order to get started. One is a corner clamp/jig and the other is a welding table.
    I've lurked around for a while and found out that its not good to weld the top of the welding table to the legs because it might cause heat distortion to the top. Of all the pictures of everyone's welding table i have seen on this forum, it seems that almost everyone just put a little tack every few inches apart, just enough to make the legs and top stick. Is this the standard procedure? or am I missing something? Am i correct to say that I want to minimize heating the top piece?
    I'll make some corner jigs before i make the table. Just have to measure 20 times before i cut/weld.
    Ohiowa, NE
    265
    all of them ive seen have been welded to the top. how thick are the parts (i.e. the top and the legs)?
    Miller Trailblazer 302
    Smith Torch Outfit
    Lots of Grinders
    Miller Elite Autodark Hood
    O'l Trusty Jackson
    3,952
    I made my frame from 3x3 angle and just tacked the 3/8" top to it to keep it from warping...Bob
    Lake of the Ozarks MO
    3,594
    Mine is tacked as well...which to me is just a few 1 inch welds at the corners.
    3/8ths thick as well. When the weld cools it can draw the top out of shape.
    Mine had a slight cup to it, so I flipped it and when I welded it, I did it where it brought it almost perfectly flat.
    I need a flat surface more than indestuctable...YMMV
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Mar 2009
    3
    i used 3x6 tube steel and basicly made a set of saw horses then took a peice of 1" plate 6' x 10' and welded it to the top of the horses of course i do alot of heavy fab and in order to use 3/8 plate id have to have supports every few inchs to keep it from warping
    Mar 2009
    25
    Quote Originally Posted by welderdude402 View Post
    top piece is 2'x4'x1/4" thick. legs/frame material are 1"x2" tubing 1/4" wall.
    I think i'll drill a few holes and bolt the top to the frame til i get half way decent at welding or taching. at the price these materials are going, i don't want to have to remake anything.
    on a side note, can someone recommend where to buy metal (tubing, sheeting, slab, angle iron... etc) in the inland empire area? I live in Upland, so anything between 57 and 15 freeway is close to me. thanks in advance.
    Austin, TX
    621
    The first table I made had a table with a 1/4" top, that warped when we welded it. I figured if I made another one, I would bolt the top down, but all of the tables I've made since have not had solid tops.
    Miller Maxstar 200 DX
    Miller Syncrowave 180 SD
    Hitachi 4.5" grinder
    http://mhayesdesign.com
    Feb 2008
    North of Phila. PA
    404
    If you are not comfortable with your welds by all means attach it some other way until you feel you can.
    A few thoughts on bolting it down. I would use machine screws and counter sink the heads myself, or drill and tap the top and run the bolts up from the bottom and grind the excess flush to the surface. carriage bolts are another option, but I hate anything sticking up on mine. They always seem to be right where I need to hold something down flat, no matter where I would put them. That top is too thin to counter sink Allen heads or std bolts. You could weld studs to the bottom, but at that point I'd just flip the table and tack the top to the frame.
    I have one small portable table that's just a chunk of scrap 1/4" plate on 2 metal work bench legs. I have a few counter sunk holes for 1/4" machine screws, but 90% of the time I just clamp the top down for the few things I need to do and then pack it back up, unless I need a clear top for something.
    Austin, TX
    621
    My current table is a 36 x 36 x 3/16 plate sitting on three pieces of 1x2 rect. tubing on top of my wooden work bench.
    Quote Originally Posted by oxy moron View Post
    Patton Steel has what you want, go south on Euclid to Mission and hang a left. You will see signs on the left side when you get to Sultana. If you cross the railroad tracks or reach the Sunkist Oranges Plant, turn around. You can't miss it.
    http://www.pattonscorp.com/catalog/
