Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
    Jan 2008
    Colorado
    673
    Smile
    LA Weld:
    Talking aluminum welding is a lot easier than doing it.
    Thanks for all the answers.
    RETIRED desk jockey.
    Miller Syncrowave 250.
    Quote Originally Posted by Craig in Denver View Post
    LA Weld:
    I think most are intimidated as the learning curve is greater. It has become second nature over time. I will say that my stack is not as clean as KB or Engloid, as I was exposed to a smoother feed by my Teacher and really had never got the perfect stack. Mine is more like ripples than stacked. I can do it but I have to think about it.
    I have a few customers that request a lower profile with very little height to the bead. I call it the "close call" as it is right there on the cusp of burn threw.
    the bead profile is more on the inside than out when you do a test cut.
    I can say also, I do not know it ALL, I am always learning, and I pick up more keeping an open mind than dictating. I have a lot of years under my belt and will be the first to say I have more to LEARN.
    Fortunately I have good equipment, nice shop and a phone when I weld myself into a CORNER.
    Mar 2008
    Battle Ground WA
    179
    La Weld/Craig and the rest of the gang,
    I too am learning to Tig Aluminum. It amazes me how demanding this process is! Like you La Weld I find I am more of a "rippler" I have yet figured out how to stack consistantly, and when I do I tend to run out of wire to feed and m y restarts mess up the consistancy. Does this have to do with using an inverter versus a transformer machine?? (just wondering or should I say hoping) LOL
    I must say I have melted a lot of filler and burned up a lot of Argon! Congratulations Craig on making the radiator repair!! My first repair was a Snow shovel (hope not to have to use it again this year!!!
    Tim
    Retired Elevator Consrtructor Local 19 IUEC
    AK bush pilot (no longer in AK) too old and no longer bold)
    Chaplain CMA chapter 26
    Dynasty200dx (new and loving it)
    MM-252 (NEW AND LEARNING IT)
    Hypertherm PM-45
    Miller 140 mig 110v
    Vtwin builder
    Jan 2008
    Colorado
    673
    Quote Originally Posted by LA Weld View Post
    More like insurmountable. =)
    With all due respect to KB and Engloid (I think they walk on 'welding' water); I don't care if my welds come out stacked or rippled, just as long as their cross section is consistant and they LOOK consistant. Sometimes dipping works, sometimes laywire works. And other times, nothing works.
    The very thought of this, makes me sweat!
    It's this thought process that keeps me in school.
    Fortunately I have a phone when I weld myself into a CORNER.
    I'm outta smilies, so "snicker".
    Quote Originally Posted by Ultrachop View Post
    It's why alum is my cocaine. :P
    See my opinion above about ripplin' / stackin'.
    and when I do I tend to run out of wire to feed and my restarts mess up the consistancy.
    I hope you're using 3/32" filler. I STILL don't 'get' 1/16". What I think I've learned about restarts: pull the filler away from the puddle. Do not try to restart. Now, restart the puddle, AND THEN, re-introduce the filler. Restarting the puddle, before re-introducing the filler has worked for me in both mild steel and alum.
    Like I said, awhile back, since you can't do this left handed, just as well send me that Dynasty.
    The cost of argon is worth my class tuition.
    After I plugged the nipple (first weld), I took the piece into my instructor to ask about the fusion between my bead and the base metal. He said it looked good and pointed out a pinhole. I said that I saw it and would catch it with my second, outer bead. Which I did. The only problem was: the instructor thought that I only needed to fix the pinhole. The outer bead was NO WHERE as pretty as the first and he told me so. =( But he hadn't see the lengthwise cracks, which would have propogated back to the surface. It's a good thing I'm THICK skinnned.
    Tim
    I'm still using a snow shovel I fixed when I was learning O/A (steel repair on the shank), even after I drove over it with the Bronco. =(
    Mar 2008
    Battle Ground WA
    179
    Craig,
    I hope us "ole" guys don't cause the youngen's to loose hope thinking they will be as old as us and still can't weld!! In truth with the help of a newly aquired friend that is a retired boilermaker/pipe welder I am gaining confidence daily! funny yesterday I ran a bunch of SS and he said they would no problem pass cert test (great encouragent to say the least) I then did some Mig beads (on your 252) that I haven't found a suitable box to ship it in) then ran a 1/8" fillet weld on AL and darned if it didn't look too bad!! (there is a God) and he held the torch today)
    I will post a few progress photos as soon as I set up some "fresh coupons"
    As for Gas $$$ I am just about to have to refill my 330cf as I am down to 500lbs!@!
    Tim
    Hypertherm PM-45
    Miller 140 mig 110v
    Vtwin builder
    Mar 2009
    Eastern North Carolina
    13
    However I personally think any Yamaha or Honda should be scrapped anyway
    I'll agree with you on the honda they arent worth a **** but I wouldn't use any motor but a yamaha. Not trying to offend you just curious to your reasons for the dislike of yamaha. I trust my life to them on my offshore rig we run 60 plus miles out. I have also had the mercury outboard which caught on fire 18 miles offshore. My duck duck hunting rig and small privateer center con also run yamaha and they are abuse to say the least.
    Mar 2009
    13
    I'll agree with you on the honda they arent worth a darn but I wouldn't use any motor but a yamaha. Not trying to offend you just curious to your reasons for the dislike of yamaha. I trust my life to them on my offshore rig we run 60 plus miles out. I have also had the mercury outboard which caught on fire 18 miles offshore. My duck duck hunting rig and small privateer center con also run yamaha and they are abuse to say the least.
    Why didn't my quote go inside the nice little blue box
    Dec 2005
    wisconsin
    830
    Quote Originally Posted by Agcadmin1 View Post
    You didnt leave the command code. ( [/QUOTE] etc.).
    Anyway back to the outboards, the history of outboards is kind of interesting. How all the companies were connected, the business aggreements etc. Anyway the basis on my feelings towards yamaha is primarily from my experience when the company I work for bought their engines or powerheads. The alloys used in the castings arent nealy as good as others, the basic engine design is more automotive and lacks durability. The gearcases are probably the worst for durability. I really cant tell you specifics...not that I dont know, I just cant tell. BTW what merc was it that "caught fire"? What model and how long ago?
    Miller Dynasty 300DX
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Miller Spot Welder
    Motor-Guard stud welder
    Lake of the Ozarks MO
    3,446
    Well knocking Yamaha and putting Mercury on a pedestal is sorta tongue in cheek anyhow when you consider how much old Merc outboard stuff was made by Yamaha in the first place. I'm sure Aaron knew this and was just trying to get a rise out of everyone.
    As for Yamaha I just hate their dealership program and the outrageous cost of their parts. I'm more of an Evinrude lover myself and am growing fonder of Suzuki.
    As for weldability.....they all weld fine. I think the old Evinrude/Johnsons have the worst castings of anyone tho hands down! (lots of voids)
    BTW, LA Weld, how much gap did you leave between your pieces? I usually go with somewhere around 1/4 to 3/16ths.
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
    Dec 2005
    wisconsin
    830
    FK,
    The only engines merc bought from yamaha were the early 9.9/15 , early 115 and early 225. In fact the 9.9/15 was a joint venture, with the powerheads actually built by merc FOR yamaha. There is more to the story then anyone outside of the companies knows. Anyway this is getting off topic
    Miller Spot Welder
