I'm going to have to get down to the local LWS and give one a test drive. I'm curious the feel of the dial when setting the voltage. I just keep imagining that the knob will be very very sensitive as you have a limited sweep of the dial to go from it's lowest, to highest setting. If you have the same sweep as a smaller machine but this machine has more of a range of potential voltage range a given amount of movement on the dial would have to give a higher change. I'll have to try one.
Mike
View Poll Results: Miller 210 with 3035 Spool Gun OR Lincoln 255C with Magnum SG?
- Voters
- 7. You may not vote on this poll
Results 21 to 22 of 22
03-09-2009, 04:09 AM #21
- Feb 2007
- 15
03-16-2009, 12:08 PM #22
Mike,
The unit has plenty of control, you can fine tune it in just like the Millermatic 252's.Kevin Schuh
Service Technician
Miller Electric Mfg. Co.
