Results 1 to 10 of 11
Thread: latest project
    Apr 2008
    dallas,tx
    207
    Default latest project with finished pics
    Just finished it today, taking it in for powdercoat tomorrow. material is 2.5" x 2.5" 11ga and 3/16 and 2" x 3/16" Should support one persone without too much trouble
    Jul 2008
    Delhi, Ontario:
    1,963
    Wink Mystery ???
    Quote Originally Posted by STRENGTH AND POWER View Post
    Is It some kind of exersize machine ?
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
    hamilton ont canada
    56
    Hi guys . Norm y are you not working today . Are you going to powercoat it with a grit in and what color are you going with.
    Hampton, Va.
    386
    What is it.
    Wheelchair
    Apr 2007
    Colorado
    35
    Default Wow
    I was wondering what that was too. It looks really great. I had no idea that wheelchairs were so stout! That thing looks like it could withstand a 100 mph front crash! Will it have airbags? Please show us the finished pics!
    Bend Oregon
    62
    What is it? It looks like a sheet metal brake. Let us know
    Miller Maxstar 150 STL
    Miller Millermatic Passport Plus
    Thermal Dynamics Dragun Plasma Cutter
    Protect your seccond ammendment rights! Join the NRA!
    3
    Looks like hyper extension - or some type of Roman chair???
    Apr 2008
    dallas,tx
    207
    Sorry about the vagueness, I had posted a pic of it on a gym forum as well and just assumed everybody would know what it was.
    It is called a 45 degree hyperextension. The large flat area is where you feet rest with the round rod on the backside of your leg just above your ankle. The rod will be covered with a 4" dia. foam roll, those haven't made it in yet. he front of your leg rests against the 2 flat plates which will also have a wooden buck with foam and vinyl over them. To use, you bend at the waist and then return back to the starting position using your lower back, hamstrings and glutes(butt muscles). the holes and rods at the front allow for large rubber bands to be looped onto them and over one's neck to provide additional resistance. The main frame will be powdercoated white with the moveable parts and parts that adjust/sleeve over others done in a black texture powdercoat. The vinyl pads will be black and the footplate will get a piece of treadbrite. I will post up the finished pictures once i get it assembled
    Apr 2008
    dallas,tx
    207
    Default finished pics
    Looks a lot better finished, Should be a bit more obvious to its use as well
    Jul 2008
    Delhi, Ontario:
    1,963
    Question ocweld how's things ?
    ocweld, Hi;
    I just saw your question to me! how are you doing work wise ?
    It's SO Slow here I'm almost at a dead stop !!
    I sure hope things pick up soon, or I'll go under this Spring !
    .............. Norm
    - LN-25 Wire Feeder
    - Spoolgun.
    - DeWalt Chop Saw .
