Results 1 to 7 of 7
    Dec 2008
    Honolulu, Hawaii
    26
    Default What joint to use?
    Hello everyone,
    Planning a future project out of 22 or 24 g. SS sheet metal that will basically be a funnel shape that will be for Food service use. Initially I had hoped to spin it on a lathe but don't have the expertise to do it this way so have opted to weld it up. The question is- is a butt joint better or a lap joint? The joint doesn't have to be completely smooth but cannot have crevices where food can get trapped. I would appreciate your input.
    Thanks,
    Gene
    alabama
    715
    What will be the dimensions ?
    XMT 350 cc/cv
    XMT 350 vs
    TRAILBLAZER 302
    MILLER DVI
    PASSPORT PLUS
    DYNASTY 200 DX
    MAXSTAR 150 STL
    HOBART CHAMP
    HF-251 BOX
    12-RC SUITCASES
    12-VS SUITCASE
    3,651
    I would butt it with a small gap then grind it smooth on the inside...Bob
    Jan 2009
    Cleveland, TN
    229
    I second the butt weld, and grind inside smooth. Do you have a slip roll? This would be the best way to form this. Using a brake is also good.
    Dec 2008
    Honolulu, Hawaii
    26
    Quote Originally Posted by fabricator View Post
    5 1/2 in. diameter opening at the large end, 3 in. at the small end, and 5 inches tall. I have searched high and low for a pre- made one but either the openings were the wrong size or the taper was too steep.
    Thanks,
    Gene
    Dec 2008
    Honolulu, Hawaii
    26
    Quote Originally Posted by wrenchnride247 View Post
    I wish a had a slip roll or a brake but I'll have to use good ole' fashioned "persuasion"!!!
    Thanks,
    Gene
    Dec 2008
    CDB Land, TN
    135
    Quote Originally Posted by genet View Post
    Thanks,
    Gene
    Thats gona be tuff, use a butt weld.
    Got a sheet metal shop close by and get them to roll it for you.
    Be safe
    Jeff
    Give more than you get and
    you will get more than ya need.
    This is true for the good and bad
    that life puts out.
