Very true and I could have welded the tube square on the channel but I like a good fit up. My thoughts are a job worth doing is worth doing right which is why I spent around 2 hours getting my saw sorted out because it's worth doing right in the end.
Thanks for everyones input, getting the saw sorted was a much better solution than grinding the ends square.
Results 11 to 17 of 17
Thread: Squaring the end on tubing?
02-25-2009, 08:46 PM #11
- Sep 2005
- 45
02-26-2009, 11:39 AM #12
You can weld a square cut tube crooked
Miller Bobcat 225 NT
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
Miller Spoolmate 200
Miller 225 Thunderbolt
SPEEDGLAS 9100XX
02-26-2009, 11:59 AM #13
- Feb 2009
- Lodi, CA
- 1,126
Fact is, if you're fabricating something (aside of butting together high pressure, with code welds, pipe), most cases it's actually easier to end up with square/precise angles, after welding, if the cut is slightly off. Start the tack, where it touches, then you have plenty of room to tap it whichever way, to compensate for the pull.
01-21-2010, 09:09 AM #14
When i worked in the big factory and did a lot of tube and beam fitting to steel plates. I just took a combo sq and found the high corner on the tube or beam than i would tack a little booger with the mig on the low side and touch it with a hammer or a small grinder until all corners were the same. Then the part would sit flat on the plate. Sometimes the tubes or beams were ready cut at the steel place and they don't give a rats butt if they are square or not...Bob
01-21-2010, 12:57 PM #15
- Dec 2009
- Custer Park, Illinois
- 92
One outfit I worked for we used to mill all our cuts. Even for simple frames, cut slightly over and mill to size. Measure our lengths with a dial caliper. Dead square and within thousandths for size.
Complete waste of time for most weldments. But it's just what you did there.
Sounds like you have the time and determination. If you want it square you can always use an "apprentice mill"....the largest flat file you have and a good try square.
Files are slow and forgiving. Leave a nice finish. Give you a personal interaction with the metal. Allows for philosophical reflection of life in general. Makes you appreciate the power tools made to replace it sometimes.
Al
01-21-2010, 06:09 PM #16
- Sep 2005
- 4,246
I agree, its a rare day when being cut square matters all that much, weld it square.
01-21-2010, 06:16 PM #17
- Dec 2007
- Oklahoma
- 641
