Im going to be putting a bunch of small bolts/screws into the bottom of a semi trailer. They will be exposed to all kinds of weather and road spray. Once in, most will stay there but the ones along the outside rail may need to be removed for occasional maintenance. What can I screw into steel and still be able to remove a year or so later? Stainless, brass, something not yet invented?
Results 1 to 10 of 10
Thread: What kind of bolt?
02-24-2009, 11:53 AM #1
- May 2008
- Belle Plaine Iowa
- 233
What kind of bolt?
Miller AC/DC Thunderbolt 225
Miller 180 w/Autoset
Old cutting torch on LPG
02-24-2009, 12:42 PM #2
- Feb 2009
- Lodi, CA
- 1,126
More info, are we going into a blind hole? Self-tapping bolts? Are you going to have access to the other side, maybe use nuts???
Generally, I try to stay away from SS, they tend to gall, and when you try to force them out, they break. More of a PITA to deal with afterwards. They won't cut with a torch, hard to drill, and if they're galled, not backing out no matter what you do.
If only a year between in and out, just stick with regular carbon steel bolts, use never-seize,,,, even if they break off, drill, heat, extract ,,,, worse comes to worse, you can just torch them off, drill new holes, tap and install new bolts an inch over from the old ones. Can't do that with stainless. Plus the cost .....
Of course if you can get to the other side, and use nuts, don't really matter either way .....
02-24-2009, 01:22 PM #3
- Sep 2005
- WY...armpit of U.S.A.
- 636
Screw or pop rivets. A grinder and a pin punch and they're out. Still depends on the backing headroom.
Miller DialArc 250
Lincoln PrecisionTig 275
Hypertherm 900 plasma cutter
Jet 14 X 40 lathe...ditto
Logan 7" shaper
Ellis 3000 band saw
Lots of dust bunnies
02-24-2009, 01:51 PM #4
- May 2008
- Belle Plaine Iowa
- 233
No access to the back side. Ill be drilling and tapping the I beam crossmembers that support the wood floor above.(Imagine a 2X4 stud wall that is open on one side now but will be sheet rocked.) I wont be using a torch on anything because Im attaching light weight plastic sheets. I think pop rivets would crush the plastic material. Does anyone make a plastic bolt?
02-24-2009, 02:25 PM #5
02-24-2009, 03:05 PM #6
- May 2008
- Belle Plaine Iowa
- 233
Thats a great place to start looking. Thanks!
02-24-2009, 04:59 PM #7
Stainless, with "never seize".
I use this http://www.lub-o-seal.com/products/datasheets/PD-CP.pdf
Here is a the site http://www.lub-o-seal.com/products/m...tml#antiseizes
Been using it for years and never had a problem getting stuff loose.Be safe
Jeff
Give more than you get and
you will get more than ya need.
This is true for the good and bad
that life puts out.
02-27-2009, 11:25 AM #8
- May 2008
- Belle Plaine Iowa
- 233
Ive decided to make a template so I can drill the holes in the same place on each crossmember. Im then going to tap the holes and screw the bolts in from the top with Loctite. Ill then hold the sheets in place with nylon fasteners from the bottom. Then if things get stuck a quick whack with a chisel will have the nut off.
Thanks to all.Last edited by Flyingpig; 02-27-2009 at 05:34 PM.
02-27-2009, 02:50 PM #9
- Feb 2008
- Guam
- 177
Stainless galling
In the marine enviourment,probably one of the worst were almost all of the galling problems I've run across have been stainless to stainless.Stainless into something different, mild steel,silicon bronze has been very rare. Use the never seize too, If not available white axle grease , no metal ingredients.
02-28-2009, 07:04 PM #10
Member
- Dec 2006
- collinsville, ok
- 86
i would go with galv.
****, any problems just buy a scarfing tip.
