Page 1 of 5 12345 LastLast
Results 1 to 10 of 44
    Default Rebuilding heavy equipment buckets
    Last week an operator called and let me know that he had broken the bucket.
    I went out and sure enough, half the leading edge had simply snapped off.
    I am contemplating the repair and will be using a T-1 plate, 12"x8'x1". What type of steel should I order(I'm guessing that there are several types of T-1 steel) and what Rod should I use?
    Thanks in advance.
    Please email me at "Shawnsapirate@yahoo.com"
    N.C.
    362
    Call the manufacture of the bucket and they will tell you what it is made of...as for the correct rod 7018 is your friend
    George W. Bush was saving your butt whether you liked it or not!
    HH210 with SG
    Lodi, CA
    1,305
    That would probably be the cutting blade, not T-1 steel. If it has a bolt-on blade, it's the "frog", also normally not T-1 steel. Any blade supplier can get it for you. You didn't list your location .... Cutting Edge Supply is a big one, many steel distributors can get it for you, plus the equipment dealers themselves.
    Oct 2008
    taxachussetts
    416
    if your going to replace the cutting edge it's going to be AR plate #400 or#600 your going to need to preheat. and AR plate is well over 110 hardness so your not going to make it with 11018 rod anyway. I've done some root passes with 110 then used 7018 for cover. it's so hard to get info from the manufacturer. they want you to have them do the work but i know that the CAT dealer here uses 7018 for there repairs. I'm sure i missed something.
    TB 325
    TB 302
    dynasty 200sd
    spoolmatic 30a/wc24
    suitcase x-treme 12vs
    miller 211
    evolution rage 2
    Akron,Pa
    152
    alright i just love bucket threads. make sure you post lots of pictures for us.
    Dylan
    RED BIRD WELDING
    "Experience is simply the name we give our mistakes"
    HH-140
    Crappy stick welder
    Victor supper range II
    Makita grinder
    more stuff i don't feel like listing.
    Apr 2006
    TAXACHUSSETTS
    1,504
    Default bucket pics you got it.
    Heres a few,but i don,t know if i,m an expert.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
    turbo38t Guest
    Oh I miss doing buckets. Nothing like taking 2 days to weld one shank on a PC1200 bucket. We used to goge the floor and sides out leaving just the lip or vice versa. Built some big old muck buckets. Bucket lips can be all different stuff but most commonly from the factory they are T1 or some foreign buckets use Hardox(sucks IMHO). I always preheat them to about 200-300 and weld with 7018. Usually put a root in with wire. Never found a good wire for doing the lip and adaptors.....but I'm sure there are some. E70m seemed to crack once in a while after some use. I guess cause it's not LoHy
    Quote Originally Posted by admweld View Post
    Apr 2006
    TAXACHUSSETTS
    1,504
    Quote Originally Posted by turbo38t View Post
    Need a good wire try lincoln 212 .068 dia mostly all i use.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    inland empire ca
    6
    does this nr 212 wire work for vertical up any thickness limitaions
    Jul 2008
    Delhi, Ontario:
    1,995
    Thumbs up Buckets
    admweld;
    Expert ? Yes You Are !!
    Great Job !!
    Norm
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
