as to the other part of your question, i think it was a question. reinforcing bar joist: I've had to run 5/8 round stock to the four corners of the angel iron this keeps the angle from twisting and letting the bar roll over or bending.
I've also had to run angle iron top to bottom next to the the center supports to make it handle more load. did i mention 15+years of structural welding.![]()
Results 11 to 20 of 31
Thread: Beam or Bar joist reinforcement.
02-22-2009, 07:52 PM #11
TB 302
dynasty 200sd
spoolmatic 30a/wc24
suitcase x-treme 12vs
miller 211
evolution rage 2
02-22-2009, 07:57 PM #12
02-23-2009, 08:43 AM #13
- Sep 2005
- 4,246
Good, good and simple and describes the sequence for lack of better words.There are several factors to consider: The strength of the beam against deflection is primarily from the material farthest from the center, which is usually the flange, so adding material to the flange will increase resistance to deflection (as show in the pic attached above) The flange material is the main element in load carrying until one of the other failure modes is met.
There are limits to this: shear and buckling.
02-24-2009, 03:13 PM #14
OK from what it sounds like judging by what Enlpck, S Berry and vin man have said, and correct me if I'm wrong.
Its stronger to add metal to the top and bottom flange of a beam instead of putting a plate in the webb area.
Next question, Does a H or I-beam work the same way as a Bar joist.
Meanining, Is the top flange under compression and the bottom flange under tension.
And how would you reinforce this, would you add material to the flanges or would you run a plate standing on end betwen the upper & lower flange.
Keep in mind there would already be proper X bracing installed along with the typical 1" angle running across from joist to joist and the beams are being reinforced to carry the load of a bigger RTU- Roof top unit.
So what do you do in this situation to reinforce this beam.
02-24-2009, 03:22 PM #15
Heres another example,
Some one wants to put a pool table in their basement but theres a column in the way so it needs to be moved 4' down to make room for the pool table.
The engineer says put a new footing in for the column and this is how you reinforce the beam.
How have engineers had you guys reinforce the beams.
02-24-2009, 04:55 PM #16
Take your pick, which one is stronger?
I have no idea!
02-24-2009, 05:04 PM #17
Forgot this one!
02-24-2009, 06:54 PM #18
02-24-2009, 07:20 PM #19
02-24-2009, 09:24 PM #20
- Jun 2004
- nj
- 204
Huh?
v-m, for the vast majority of situations where a horizontal beam carries a vertical load, the web is NOT the limiting factor. Yes, the flange is what provides resistance to bending under side loads, but this is because the flange is the part that has material farthest from the neutral plane in side load (neutral plane: the plane through the material where no stretching or compressing takes place in bending). The material farthest from the neutral plane (the flange for vertical load in the original example) undergoes the most stretch/compression, and is therefore under the most stress, and is most important in carrying load in cases where shear isn't dominant and there is sufficient bracing to prevent buckling.
Portable-Welder: the load distribution is generally the same with a bar joist and a beam-- the load top is under compression and the bottom under tension in both-- but the bar joist is much less stiff against side load and buckling to the side. I would STRONGLY suggest getting and engineer to evaluate a situation like this and provide details. That is what he is paid for and why he carries insurance. Each situation is different.
In the first case you described, I would guess that the solution would be a) replace the joist with a heavier one, b) reinforce the joist by adding material at the top and at the bottom, or c) (most likely is the capacity and space are there, as it is easiest and cheapest) run W-beams ACROSS the joists to spread the load over several of them, rather than one or two. Buckling is likely not an issue for any of these solutions if the cross bracing is sufficient in the first case, unless the load is quite large. In the case of an S-section (I-beam), not much is gained by reinforcing between the flanges in most cases, as they are fairly narrow and thick. In a W-section (H-beam; wide flange) the reinforcement greatly reduces the risk of buckling in longer beams, but is only one of several solutions. If the beam isn't too long relative to its size, it is of little use.
In the second case, lots of options. A simple case: most likely would be a pair of columns, one to each side of the original, and a beam to catch load where the original was, if the column needs to move sideways. If the column needs to move along the beam, it can get quite complicated, in particular because small increases in span (say from 12' to 16', from moving 4') can require a much larger beam. The size of the beam needed goes up much faster then span for a given load, and can change the limiting factor from allowable deflection to load carrying capacity based on yield, shear, or buckling.
For more information: See (among many others) _Structures_: Schoedek; _Strength_of_materials_: Den Hartog; _Procedure_book_of_arc_welding_: James F. Lincoln foundation; _Design_of_welded_Structures_: Blodgett; AISC_manual_of_Steel_construction_:AISC;
