I was taught, and have done as normal procedure, to bleed my lines and regulators after using my o/a kit. This apparently takes pressure off the valves, lines, and regulators.
Do you (group) do this with your Ar. on your TIG machines? I've done it and not done it. Would like to know if there is an advantage either way.
Results 1 to 7 of 7
Thread: Bleeding TIG
08-12-2007, 06:16 AM #1
Bleeding TIG
08-12-2007, 07:12 AM #2
advantages?
I would think it is a good idea to bleed the lines for the occasional user but if you run your stuff off and on all day long it would eat up a lot of gas. Me personally, I don't do it unless I'm disconnecting the hoses and regulator for transport. Dave
08-12-2007, 10:04 AM #3
I THINK as in not sure that O/A regulators are the only ones needing bleeding and that is because they are diaphragm pressure regulators and the one on a Argon or CO2 shielding gas cylinder are flow regulators.
A diaphragm regulator wants the pressure relieved when not in use so the "T" handle don't come bursting out when the diaphragm beaks.
TJTJ______________________________________
08-12-2007, 10:43 AM #4
The inert gas regs. that have the ball in a tube style flow meter are generaly of a diaphram style set at a pre set working pressure, but I'm not sure what the ones with a CFH gauge are. I always just make it a habit to purge the regs. at the end of the day just to stay on the safe side. I've noticed that it does seem to prolong there life some what.
08-12-2007, 05:11 PM #5
- Sep 2005
- 100
I was taught from the Victor torch educator guy, for lack of a better name, that you should bleed off your O/A tanks not only to save the diaphrams, but also because over a period of time the gasses mixed in the torch can become unstable. Sounds crazy, but he showed us photos of blowed up torches.
08-12-2007, 06:56 PM #6
- Apr 2007
- Ventura, California
- 102
Purge at the end of the day
I was taught to close the tank valve and purge the Argon lines, at the end of the day. This no only relieves pressure on the system, but if there is a slow leak somewhere you won't slowly lose Argon all night long.
08-13-2007, 12:26 PM #7
Thanks for the answers guys. You've confirmed my suspicions. It is sometimes several days between my TIG use and it makes perfect sense to purge the lines. Like I said, I have done so in the past except for a couple of times when I got lazy or shut the power off and disconnected before realizing I hadn't cleared the lines.
I shall make this part of my shutdown procedure and form the habit. The minimal loss of gas when purging isn't as important as protecting my equipment.
Also, Sumarai Dave, your comment about a leak is a very good point. I would be very unhappy to come into the shop one morning and find that I didn't have any Ar. even though I leak test my connections at least once a month. Murphy's Law is still in effect. However, this should only happen if I totally forgot to close my tank valve. Not likely, but possible.
