Yeah I'm not 100% about my welding to say I would be doing it safely. I'm also not certain my machine will do steel that thick and get full penetration. My next door neighbor is a welder by trade so I could get him to do it, or at least look over my shoulder. I would like to learn to weld good enough to have that sort of confidence, but I realize the learning curve for that is very steep.
100% sure. I bought it from a friend, who claims it's been stuck for "a while"
I guess I'll just keep at it. I may end up cutting the back off with the portaband. At the very least, that will let me get some pb blaster on the other end
Results 11 to 20 of 23
Thread: trailer hitch question
02-19-2009, 07:29 AM #11
Member
- Jan 2008
- 87
Millermatic 180 Auto Set
02-19-2009, 08:09 AM #12
- Feb 2008
- North of Phila. PA
- 404
The ones in our work trucks get stuck from time to time. Chain and a good sized tree works for us. If you are worried about the tree a heavy tow strap works well also. We have a nylon lifting strap we use to wrap the tree with and then use the chain. You don't leave a ton of slack in the chain then jump on the hammer. Easy forward until you feel resistance and then apply solid pressure. If that doesn't work a small jerk or 2 might get it to move.
Also backing into a solid surface like a concrete loading dock may free it up. Concrete not block. Again use common sense. Don't floor it and slam into the wall in reverse. Back up and give it a solid thump or 2 then see if it will pull out. Use some force but don't hurt yourself. Most 2" hitches are designed to pull / push up to 10K+ so you can go ahead and use some of that force to free it up with out hurting too much.
02-19-2009, 08:26 AM #13
Member
- Jan 2008
- 87
02-19-2009, 10:16 AM #14
The chain and tree might work depending how rusted it is in there.
Ive done this a few times over the years, I block the truck wheels all 4 hook a comalong to the back of my hilo and also block hilo wheels, apply pressure ( Tension ) heat with a big rose bud torch, quench it with a water hose which shrinks itheat again and repeat, beat it with a hammer in between heat and that helps break the rust away,
I actually hit the tube where the rust is.
Then warm the tube one last time and hit with sledge hammer to get it out.
Thats how you get the really stubborn ones out.
Unfortunately it doesnt sound like you have the proper equipment so you might want to try your local welding shop.
02-20-2009, 04:37 AM #15
- Mar 2008
- 148
I had this happen on a friend motorhome a few years ago. We tried everything including a 30,000 pound "snatch'em strap" tied to a tree and we couldn't remove it. We finally removed the whole hitch, cut a slot in the outside tube and used a hydraulic press to force the hitch out of the receiver.
We then rewelded the slot and reinstalled the hitch.
Nothing was bent, just lots of rust from not being removed for years.RoyB
Dartmouth, MA
http://www.rvbprecision.com
Millermatic 185 MIG
Miller Diversion 165
Purox W200 O/A
Grizzly 9957 Mill
Grizzly 4030 Metal Band Saw
Grizzly 1050 Knife Belt Sander
Jet 1236 Metal Lathe
TP Blast Cabinet
02-20-2009, 06:03 AM #16
- Jan 2008
- VA
- 298
I seem to get asked to help with issue more than I deserve. Being around less than handy weekend racers with tow rigs does not help. I use a web strap around a tree or other imovable object to pull hard and then set the brake. Not a chain, webbing, so there is some strech and spring load. Heat and beat side to side with BFH while under tension to remove. Heat the outside good and hot but not the glow point and spray water through the pin hole to cool the inside and shock it. I had one pop out at me when I shot some cold water in. The owner was suprised as he had been fighting with it for a while and had a pile of busted tools to show for it.
Weekend wannab racer with some welders.
02-20-2009, 07:44 AM #17
Member
- Feb 2008
- Western NY State
- 41
Trailer Hitch Problems
This is an interesting thread. I have kind of a different problem since I usually remove the hitch from the receiver. This promotes rust inside the receiver and since I don't do much towing in the winter it seems like every spring I am out there with chisels, files, die grinders trying to clean out the rust. The front end of the receiver is closed making it hard to get at the inside. Does anyone have suggestions for methods of cleaning the receiver.
02-20-2009, 07:53 AM #18
Member
- Jan 2008
- 87
02-20-2009, 08:02 AM #19
I had the same problem with a used truck that I bought. Since the back is boxed in, cut, burn or drill a hole in the end, weld a large fine-thread nut on the back . . . 1/2 to 3/4 . . . and use a bolt as a jackscrew.
Jim
02-20-2009, 08:45 AM #20
- Oct 2006
- Illinois
- 458
hi, if you decide to use the tree and chain removal operation I would suggest having a plain car or truck tire no rim and chain from tire to truck and tire to tree. This is something a old farmer told me to do. It really works great and saves the jerking and trans plus gives you that extra stretching
