Use an O/A torch.
How much is the deck bowed? What thickness is it?
Results 11 to 20 of 21
02-21-2009, 07:06 PM #11
02-21-2009, 08:16 PM #12
Member
- Sep 2005
- 82
the worst part maybe 1/4" bow, 1/8" decking
MM 251
DYNASTY 200DX
SPECTRUM 625
STARTS AND STRIPES BIG WINDOW ELITE
02-21-2009, 09:27 PM #13
I have hear you can heat shrink bowed areas by applying heat to a bowed area with an OxyAct torch follwed by a cool wet towel. Don't know the exact technique though.
Millermatic 350P
Dynasty 350DX
Trailblazer 302
Spectrum 2050
Spectrum 375 Extreme
02-22-2009, 04:56 AM #14
With only a quarter inch bow in 1/8 inch material the first example may be to aggressive.
You may want to use a series of small circles.
Do not work from the top, inside the concave part of the bow you will make things worse! You have to work on the convex side of the bow, from under the truck. Heat a small circle spray with water and let cool to the touch. First try heating to a dull red. In that thin of material if you heat to cherry red you will cause dimples in the deck. I suggest you do not work too much in one section. Heat 3 or 4 circles in one section then move to another area. Not knowing where or how far apart the ribs are is a challenge to give advice.
02-22-2009, 07:11 AM #15
I just finished reading Sink or Swim Metalworking by Tom Lipton. He has a good section on flame straightening and heat shrinking - describing why it is working - so you know how to make it work. Pages 233-244. You can go to amazon and do a "search inside this book" for "shrink" and preview/read these pages. I'm not going to tell you if you should buy the book or not, that will be your own decision.
Miller Econotig
Hypertherm 380 Plasma
Hobart LX235 AC/DC Stick
Lenco Spot
Dan-Mig 5000
O/A Smith rig
02-22-2009, 07:26 AM #16
If it's only 1/4" bowed then weld on the new supports..... use a bottle jack to push it into place..... and 1/4" isn't much of a bow
HH210 with SG
02-22-2009, 07:37 AM #17
- Feb 2005
- N.E. SD
- 1,368
I agree with Mike. 1/4 is no big deal to get out. Cut your new supports and push them up into place, weld them in and you are done.
Jeff
02-22-2009, 10:09 AM #18
If the metal is stretched, what will he do with the excess?
It will have to go somewhere. I’d tighten those molecules up until they’re shoulder to shoulder.
Other wise the bed may look like a washboard.
02-22-2009, 01:43 PM #19
- Feb 2005
- N.E. SD
- 1,368
02-22-2009, 02:14 PM #20
I think forcing the deck up and installing more ribs is a great idea!
Even if there were a little washboard look to the deck, before stitch welding the deck to the new ribs that is when I would throw a little heat to the high spots from the top, why work under the truck anymore than you have to when you can tighten the deck up from above.
