Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Default getting steel flatbed deck flat again
    ive got a steel flatbed that didnt get enough support under it when it was first built and now the 1/8" steel deck is pretty warped are there any tricks to getting it flattened back out after i add the support back to it? i was gonna get some 1/8" angle and run two back to back to make a T and put them every 16" after i did that i was thinkin about putting a bunch of bolts in the deck and then welding it all down so i can pull the bolts back out. i just wanna get it flattened back out without having to replace it all
    MM 251
    DYNASTY 200DX
    SPECTRUM 625
    STARTS AND STRIPES BIG WINDOW ELITE
    Sep 2008
    ****son,TN 37055
    34
    I've used "dogs and wedges" and a big beater when I needed to get plate better aligned before welding. If you can't get to the backside this might be a problem though. What about welding a "lifting eye" of somekind to the spots that need work and pulling up on it, is that possible?
    Aug 2006
    N.C.
    362
    The problem is that the steel is not only bent it is stretched... you could try heating the top side with some pressure on the back side to help it return but you will more than likely not get it back 100%.... why not re-skin / deck it.... yes it will cost more but the time and aggravation it will save will pay for itself ........ of course to find out just how much you would have to try and straighten what you have so I guess once you get into straightening it and say to yourself "**** Mike was right I should have just re-skined this ****ed thing" I told ya so .... how badly warped is it is the big deciding factor ....if it is just a little bit wavy then heat and beat but if it looks like the bottom of a dump truck bed then re-skin it
    HH210 with SG
    i would definately like to reskin it especially have had alot of thoughts of using rumber rubber flooring deck if i redo it. its nowhere near dumptruck bed
    if money wasnt an issue i think it would get reskined real quick
    MM 251
    DYNASTY 200DX
    SPECTRUM 625
    Mar 2008
    Battle Ground WA
    179
    Barebackjake,
    I am a little confused, are you able to get under the deck to weld the t's to the frame, bolt down from the top? If that is the case, you could likely get most of the warp out by using oversized holes where the bolts pass through and heat, BTF out of it with the bolt snugged to hold it and then as you said weld it, (depends on how big of an area you have to deal with) How about a couple of photos??
    Tim
    Retired Elevator Consrtructor Local 19 IUEC
    AK bush pilot (no longer in AK) too old and no longer bold)
    Chaplain CMA chapter 26
    Dynasty200dx (new and loving it)
    MM-252 (NEW AND LEARNING IT)
    Hypertherm PM-45
    Miller 140 mig 110v
    Vtwin builder
    ill try to get some pics today, oh yeah i can get under it im gonna take it off the truck to do all this im gonna re work the back bumper at the same time. really thinkin about the rumber option at the moment too since then i wouldnt have to rhinoline/linex the deck would just have the border parts to do and that would save alot there. i need to get everything sandblasted when the bed comes off too thinkin about gettin one of the attachments for my pressure washer to use it for the sand too
    MM 251
    DYNASTY 200DX
    SPECTRUM 625
    Mar 2008
    Battle Ground WA
    179
    Darn,
    Looks like you got a lot of "thinkin" to do?? Once you get it off you will be able to make a better choice of the options.
    Tim
    Hypertherm PM-45
    Miller 140 mig 110v
    Vtwin builder
    thats the only thing most of the thinkin has gotta be done on the truck, i would have from thursday night to sunday night to have it off fixed, painted, and back on the truck. reworking the back i can build the new back then just cut the old one off and weld new on its just the decking options
    MM 251
    DYNASTY 200DX
    SPECTRUM 625
    Jul 2006
    1,508
    Do you know anything about heat shrinking?
    the heat shrinkin i think of first is for wires! lol
    are you runnin beads underneath the deck to make is shrink? i have heat shrunk a bearing race to get it out before thats close as ive had to do it
    MM 251
    DYNASTY 200DX
    SPECTRUM 625
