I am currently in the process of rebuilding a horizontal/vertical metal band saw. I got it for free several years ago, and am just finaly getting around to cleaning it up. I just put all new bearings on it, and made the first cut. It was cutting great and then it sort of jumped and started cutting very slow and crooked. When I shut it off and looked at it, there are a coouple very large stretches where the teeth are broke off. It is sort of odd, they are not worn off, they are clearly broken off.
So, I need to get a new blade. What would be the best type/tooth count to get? It will mostly be cutting tubing and flat stock, up to 1/2". I will be using it for aluminum down the road, but that is a ways off still.
Thanks for any suggestions.
Results 1 to 10 of 14
Thread: Band saw blades?
02-09-2009, 11:16 PM #1
Member
- Feb 2009
- Pacific NW
- 97
Band saw blades?
02-10-2009, 05:15 AM #2
- Nov 2005
- 130
I'm thinking that I have a 10/14 on my saw that I use for everything thicker than 16g.
If you were doing production runs you would probably want to take the time to change to the optimum blade for whatever you were cutting.
Others will chime in.
02-10-2009, 06:34 AM #3
http://www.countrysaw.com/ has any blade you could ever need...Bob
02-10-2009, 06:47 AM #4
- Oct 2007
- 2,949
Band Saw Blades
That's what I'd suggest, 10/14 tooth blade. If you have a 64 1/2" (common) you can get standard blades at Home Depot for around $10. A higher quality "bi-metal" blade goes for around $25 each. I've had the teeth break off of new blades too. I bought my old "PowerCraft" 64 1/2" saw from my neighbor for $25 last year! You can get a belt for the motor at NAPA, check the lube in the gear box, use a good hypoid lube, not grease. Mine doesn't cut perfect, but it suffices until I get a new one. When we all get our "stimulus package" I'll buy a new JET.
(LOL)
Dave"Bonne journe'e mes amis"
02-10-2009, 07:20 AM #5
- Apr 2008
- 171
grizzly and enco have a lot
02-10-2009, 11:57 AM #6
Member
- Feb 2009
- Pacific NW
- 97
Thanks. I think I will run down to Harbor freight and see what they have.
02-10-2009, 12:53 PM #7
- Sep 2005
- WY...armpit of U.S.A.
- 636
Miller DialArc 250
Lincoln PrecisionTig 275
Hypertherm 900 plasma cutter
Jet 14 X 40 lathe...ditto
Logan 7" shaper
Ellis 3000 band saw
Lots of dust bunnies
02-10-2009, 08:05 PM #8
I vote bi-metal. I use Lennox from my LWS
Miller Bobcat 225 NT
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
Miller Spoolmate 200
Miller 225 Thunderbolt
SPEEDGLAS 9100XX
02-11-2009, 05:19 AM #9
- Nov 2005
- 130
Take it for what it's worth -
I have a belt drive Enco (same as HF) 7x12.
If I want to cut say a 10"x1/4" piece and stand it up in the saw I know it won't be square, just the nature of the machine, cheap.
If I lay it down I know that the cut will load with chips and wreck the blade.
I keep my belt a little loose so that if the blade locks up the motor pulley
will spin inside the belt. It makes a horrible screeching sound but at least I
haven't ruined a $25. blade.
Also pays to keep an eye on a long cut like this and lift the blade occasionally
and clear the chips.
02-12-2009, 11:56 AM #10
- Oct 2008
- 25
The blade loads with chips even with cutting fluid?
Do you have any other comments about this saw. I was planning on purchasing it as I thought it would be a better choice than the 4x6 that HF sells but if the quality is the same maybe I am better off just getting a small but high quality machine.
ThanksLast edited by dudical26; 02-12-2009 at 12:41 PM.
