Hello all,
I am planning a project that will be a custom SS wire basket constructed with 1/8 or smaller wire. Has anyone made something similar and can offer any advice?
Thanks in advance,
Gene
P.S. I have a MM 140 and will most likely use tri-gas.
Results 1 to 5 of 5
Thread: Wire basket help needed
Hybrid View
02-15-2009, 12:15 AM #1
- Dec 2008
- Honolulu, Hawaii
- 26
02-15-2009, 10:42 AM #2
- Nov 2007
- Central Idaho
- 190
What he said. Try mcnichols.com.
02-15-2009, 11:04 AM #3
Never made one from SS..... But I have made several from Ti
I would not have fun doing it in SS using a 140A GMAW... not that it can't be done but you will nat have a lot of control and at some point you will pull the trigger for a second too long ans will end up with a pile of metal on the table, and a hole in your basket.
02-16-2009, 12:38 AM #4
- Dec 2008
- Honolulu, Hawaii
- 26
Reggie: Expanded metal or mesh won't work for this-it is basically a custom
form for frying food. Parts of it will be constructed out of perforated sheet though.
mikeswelding: I surely will check out mcnichols.com-I can always use a good souce for supplies!
Fatfab: That's what I was afraid of-any suggestions on settings?
Thanks again to everyone,
GeneLast edited by genet; 02-16-2009 at 12:42 AM. Reason: clarification
02-16-2009, 03:24 AM #5
- Feb 2008
- Guam
- 177
Find a net man
Look around the fishing boat docks,ya might find a guy that repairs nets.He would be able to weave one up in no time if you had a ring already attached to a handle and a small spool of the stainless wire .
