Results 11 to 20 of 37
    Nov 2008
    East
    91
    Quote Originally Posted by welderman23 View Post
    but i WANT to watch the arc
    Liability
    Big 40 Deluxe
    12RC
    WC-24
    30A
    Dynasty 700
    XMT 456
    Custom Cart w/the following:
    S-74DX
    Optima Pulser
    Coolmate 3
    XR Control Box
    XR Alumna Pro Python W/C
    CP 302 w/22A
    MM210
    Synchrowave 180 SD
    Spectrum 2050
    TB 302
    12RC
    WC-24
    30A
    HF 251 D1
    Dynasty 200 Coming Soon
    Akron,Pa
    152
    i still get a laugh when i see people staring at someone welding. maybe the sign should say "dont watch the bright blue light" i dont know if some people will know what an arc is. nice rig though are you on your own?
    Dylan
    RED BIRD WELDING
    "Experience is simply the name we give our mistakes"
    HH-140
    Crappy stick welder
    Victor supper range II
    Makita grinder
    more stuff i don't feel like listing.
    Nov 2008
    East
    91
    Quote Originally Posted by migwelder05 View Post
    Nope, not out on my own yet. Where I work compensates me too well to go out on my own, and I'm busy averaging 65 hours a week. It's very hard to walk away from that.
    Someday? Maybe.....
    Mainly I'm putting this rig together because I'm tired of passing up extra income because I'm not mobile.
    Big 40 Deluxe
    12RC
    WC-24
    30A
    Dynasty 700
    XMT 456
    S-74DX
    Optima Pulser
    Coolmate 3
    XR Control Box
    CP 302 w/22A
    MM210
    Synchrowave 180 SD
    Spectrum 2050
    TB 302
    12RC
    WC-24
    30A
    HF 251 D1
    Aug 2004
    Milan Michigan
    1,793
    I have 2 ingersorand compressors one on each truck, definately spend the little extra for the honda.
    Nov 2008
    East
    91
    Just curious as to why.
    I have a Speedaire on the Humvee at work with the Honda and I wasn't overly impressed. Coldblooded, loud, and the starter "CLANGS" into the flywheel upon startup.
    Overall I'm much more impressed with the Kohler powered IR.
    Big 40 Deluxe
    12RC
    WC-24
    30A
    Dynasty 700
    XMT 456
    S-74DX
    Optima Pulser
    Coolmate 3
    XR Control Box
    CP 302 w/22A
    MM210
    Synchrowave 180 SD
    Spectrum 2050
    TB 302
    12RC
    WC-24
    30A
    HF 251 D1
    Baldwin, NY
    275
    Quote Originally Posted by Number 1 View Post
    Got my air compressor mounted. 13 HP Kohler, electric start, 30 gallons at 175 PSI, 25 CFM 100% continuous duty.
    Got a great deal on it at Tractor Supply of all places.
    Next up are cable reels which should be here next week, and Monday I'm gonna head down to the LWS and order my wire feeder, freek box, aluminum spool gun and some miscellaneous cables.
    Nice rig, but that tongue doesnt look very strong, especially for the length. But it looks alot cleaner/neater then my trailer....
    Voigt Precision Welding, Inc.
    Miller Dynasty 200 DX, Miller Syncrowave 250, MillerMatic 252, Hypertherm Powermax 45, Auto Arc Trailpower 8000,272+187 lb Peter Wright anvil, 120 lb Fisher-norris, and more! Buffalo drill press, Grizzly Horiz. Bandsaw, Edwards shear, Barth Shear, bantam mechanical ironworker, Hopkins fly press, Doall Bandsaw, brown and sharpe surface grinder.
    2007 Silverado 2500HD (tow vehicle)
    2000 Camaro SS (Race car)
    Nov 2008
    East
    91
    Quote Originally Posted by Badd00SS View Post
    The tongue extends almost half way into the trailer for it's overall length and is tied in well. The tongue and cross supports are all welded to the diamond plate skin. I'll look for pictures of the bare frame.
    Edit-found it.
    Even so, the tongue only has to support tongue weight.
    My tongue weight is 200 lbs, which I plan to reduce slightly by rearranging my equipment a smidge.
    I think 2x2x.250 wall box can support 200 lbs over a 42" span.
    I have zero sway or flex up to 65 mph. It tows really nice.
    Now consider the yield and tensile of A36.....yield is 36k and tensile is 58-80k depending upon the type/shape used. Even considering very excessive G forces in an accident, say 10 Gs, the tongue will see a 2000 lb load.....
    Still think it's weak?
    Most crap is WAY overbuilt.
    I'm a minimalist that likes clean designs.
    And in the unlikely event it ever bends in some horrendous accident, I'll cut it out and replace it with 2x3 or 2x4 .250 wall box tube and call it a day.
    Big 40 Deluxe
    12RC
    WC-24
    30A
    Dynasty 700
    XMT 456
    S-74DX
    Optima Pulser
    Coolmate 3
    XR Control Box
    CP 302 w/22A
    MM210
    Synchrowave 180 SD
    Spectrum 2050
    TB 302
    12RC
    WC-24
    30A
    HF 251 D1
    Aug 2004
    Milan Michigan
    1,793
    I like the honda because it has always started except 1 time when it was below zero.
    A friend of mine Vern had the Kohler and in the winter he always had to run a hose off the exhaust of the welder over to the compressor to get it started while mine always started unless like I said it was down around zero.
    Alot of it may be personal experience and I've had the best luck with the honda.
    Corunna Ont, Canada
    454
    Default reels
    Hey Number1 what reels did you decide to go with??
    Railmen
    2007 Trailblazer 302G
    2004 Invision 354MP
    1999 60 series feeder
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    older Hobart hefty wire feeder
    Hyperthrem 600
    Maxstar 150S(such a cute welder)
    had and sold........
    2003 XMT 304CC/CV
    1947 Lincoln SA200G short hood
    1963 Lincoln SA200G
    1975 Lincoln SA200G(best machine ever had )
    1970's Lincoln SAE400G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
    Nov 2008
    East
    91
    Cool.
    Thanks for the response.
    Personally, had the been the same price, I might have gone with the Honda. However, given how both of them start and run under my "normal" usage conditions, I would not pay a premium for the Honda.
    Below zero? You're hard core. I'm from Chicago but only 4 years in Virginia has made me soft.....I wouldn't even think of welding outside in less than 20*F temperatures. That's a good reason to curl up next to our Dynasty 700 and tig aluminum all day.
    Big 40 Deluxe
    12RC
    WC-24
    30A
    Dynasty 700
    XMT 456
    S-74DX
    Optima Pulser
    Coolmate 3
    XR Control Box
    CP 302 w/22A
    MM210
    Synchrowave 180 SD
    Spectrum 2050
    TB 302
    12RC
    WC-24
    30A
    HF 251 D1
