Results 1 to 10 of 10
    Nov 2008
    11
    Default 2" receiver hole size
    Building a winch adapter to fit in my 2" receiver. I know the hitch pin is advertised as 5/8", but is 5/8" really the drill size used to make the hole or is a slightly larger drill actually used by the industry?
    Salem ,Ohio
    3,908
    Cool
    5/8" is the standard. Maybe yours has some powder coat in the hole...Bob
    Jan 2009
    cranbrook b.c canada
    2
    if the pin is 5/8 then the hole needs to be bigger than 5/8 like 35/64or 11/16
    Feb 2009
    Island Falls Maine
    562
    Default open er up
    drill the hole 11/16 just so you know shell fit. wont hert it any being a little on the big size.
    Sep 2008
    Toronto, CAN
    52
    Default Hitch Receiver pin size
    Hi,
    I have a front hitch on my Exploder and had to weld a license plate holder together, cops told me to get her done. 5/8" drill did the trick for me with paint on it. 1/32" bigger won't hurt with paint on it.
    Trailblazer 325 EFI
    SVI 300i cvcc
    Mig 4HD & Mig 2E wire feeders
    Ultra-Pulse 300i Pendant
    EAS-IV Electronic Arc Starter and Plumbing Box
    Powermax1000 G3 Series
    AC-225 Arc Welder
    Feb 2005
    N.E. SD
    1,378
    So, you have the receiver, right? And it has the hole in it, right?
    Jeff
    Nov 2008
    11
    Quote Originally Posted by J hall View Post
    Yes, but the hole is well used. I measured 3 receivers, two hitches and 3 hitch pins. All had different numbers, but since they are all used and may have wear, I thought I would ask. I thought some full time fabricator might read the question and know the answer.
    Jan 2007
    lexington,Ky
    528
    we drill all the ones we make 1/64 over 5/8 works for us.
    Feb 2008
    868
    In structural steel applications, the hole drilled has 1/16" larger diameter than the nominal bolt size. For example, a 3/4" bolt would be drilled 13/16." And the calculations of the connection strength figure a hole 1/8" larger than the nominal bolt diameter to include an additional 1/16" of damage that can happen in drilling and punching operations (AISC D3.2).
    However, this practice is necessary mainly due to multiple bolt connections where alignment of all bolt holes would be impossible (due to fabrication tolerances) if each hole were drilled exactly the nominal diameter of the bolt used).
    That said, diameter you drill the pin holes depends on the tolerance of the hole location... the more slop, the larger the hole needs to be to accommodate it. At a minimum, add 2 times your location tolerance to the diameter.
    If you can locate AND DRILL the center within 1/64", then add 1/32" to 5/8". Or just drill it 11/16" and use the standard the steel industry does.
    Feb 2005
    N.E. SD
    1,378
    Quote Originally Posted by thito01 View Post
    Now I see where you were headed!
    Jeff
