Results 1 to 10 of 16
    Feb 2007
    Olive Branch Ms
    129
    Default Spoolgun frustrations
    I think I finally figured out my problems with my spoolguns. My heat was too high. All along I was thinking I gad gas coverage issues. The MM 210 gives a setting of 6/70 for 1/4", I turned it down and things got much better. I found a setting of 5/60 worked real well. Heres a few before/after pics. Adam
    Webb's Welding and Repair LLC
    MM210 w/a 3035 spoolgun
    Spectrum 625
    Trialbazer 302 w/HF
    http://webbsweldingandrepair.com/home
    Feb 2007
    Olive Branch Ms
    129
    I thought these got resized, apparently not. sorry for you guys w/dialup.
    Spectrum 625
    Trialbazer 302 w/HF
    Salem ,Ohio
    3,894
    Cool
    Nice work. Spoolguns are tricky at first. By the time you get them set right the jobs done unless its a big one...Bob
    Mar 2007
    Oahu, Hawaii
    2,469
    nice job! big difference!!!
    I'm not late...
    I'm just on Hawaiian Time
    Feb 2008
    Milwaukee WI
    57
    Wow;
    what a difference; very nice weld in the last pic
    Millermatic 210
    National City CA
    1,086
    Looks like my before and after shots. Before I learned to tig aluminum and after.
    I've never seen miged aluminum and have to say I'm impressed.
    Miller Syncrowave 200 W/Radiator 1A & water cooled torch
    Millermatic 252 on the wish list
    Bridgeport Mill W/ 2 axis CNC control
    South bend lathe 10LX40
    K.O. Lee surface grinder 6X18
    Over 20 years as a Machinist Toolmaker
    A TWO CAR garage full of tools and a fridge full of beer
    Auto shades are for rookies
    www.KLStottlemyer.com
    Feb 2007
    Olive Branch Ms
    129
    Thanks for the replies, I prefer to tig but the spoolgun is so much faster. I am going to start working on my vertical with it now that I have my welds looking decent. Adam
    Spectrum 625
    Trialbazer 302 w/HF
    Mar 2007
    MIRABEL , QUEBEC , CANADA
    50
    Thanks For The Advice And The Pictures , I Have The Same Set Up As You , But So Far The Spool Gun Is Still Brand New In The Box , Did Not Have A Chance To Use It , But It's Comming .
    Bobby
    FABRICATION-CRÉATION K ZEN
    MILLERMATIC 210
    SPOOLMATE 3035
    SYNCROWAVE 200
    HYPERTHERM 360
    Feb 2007
    Ukiah, Ca
    280
    I recently bought a 3035 for my mig machine,was very impressed with the ease of welding & weld quality. The recommendations inside the welder cover are very hot. I used to work at a job where I would use a Spoolmate II. It was very finicky, always burning back & ruining tips. I still use Tig for most of my Aluminum welding, but a friend just got me a side job of some forklift ramps; the spoolgun will get a workout.
    AutoArc 230 (MM 210)
    3035 spoolgun
    Spectrum 625
    Dialarc HF w/Coolmate 4
    i have a 210 with a spool gun and noticed that very same effect.. i did a alum. project a while back and had to crank it down .. even though usually the alum. needs more heat the steel.
    also dont forget you may had a little higher input of voltage then what the machine is calibrated for.. i know i get exactly 234 out of my outlet.. and im linked for 230 on my machine..
