    Bend Oregon
    62
    Default Snail "Bullet" Trap
    My other hobby besides welding is shooting sports. I was looking on some web page and I saw something called a snail trap. I want to replicate it but make it tons smaller. It is designed for indoor shooting ranges. It works kind of like a one way door. It is composed of a square opening that tapers down to a smaller opening blocked by a one way metal or hard rubber flap. When the bullet enters drum, the flap shuts behind it. The bullet spins around the drum and slows down. I want to shrink it down to a 2'x2' entrance. It needs to survive a .22 LR bullet. Any suggestions on material thickness or does anyone have one of these. I will post pics when I find them.
    Miller Maxstar 150 STL
    Miller Millermatic Passport Plus
    Thermal Dynamics Dragun Plasma Cutter
    Protect your seccond ammendment rights! Join the NRA!
    3,892
    There are some pics already in the forum. Search bullet trap at the top. I just used 4" black pipe welded to a 3/8" plate on a 45 degree angle. The red circle has what is left of a .44 mag slug...Bob
    Nov 2008
    I work part time at an indoor shooting range.
    .22lr will clog up a snail trap in short order.
    The soft exposed lead and low energy just smear the lead against the steel.
    Feb 2008
    North of Phila. PA
    404
    point45 Welcome to the forum, good to have you with us.
    welder_guy if all you are shooting is .22 LR then a standard slant wall trap will work fine. The ones Cabelas and places sell are fairly lightweight steel so they shouldn't be hard to build at all. Some where I have a set of plans for one I got from a buddy of mine. I think he got them thru the NRA bookstore. I'll look but don't hold your breath, its been years since I looked at them. Lord knows where they are if I even still have them.
    One thing to remember regardless is to set up some sort of exhaust ventilation if you shoot indoors to remove any airborne lead dust.
    Oct 2008
    New Mexico
    4
    Default Snail Bullet Trap
    Try this URL and click on "Snail Bullet Trap" about eight items up from the bottom of the left side menu
    http://www.parmarng.org/freeidaho/AlSkDjFhG/index.html
