Thread: Ring roller
    Dec 2008
    Scotland
    7
    Default Ring roller
    l copyed this ring roller from one a fella on here made,l printed off the pictures and made it from that,the rollers are track pins from a cat dozzer m/c out to take the bearings.
    Island Falls Maine
    562
    Default looks good
    Did A good job on it looks like it wiil work good for you.
    Dec 2008
    Scotland
    7
    Default ring roller
    l used it to make the handle.
    Chicago-ish
    282
    Nice work. How did you cut the slots that the rollers sit in?
    Nov 2008
    Kansas City Metro
    387
    Nice project beetlejac. I am just wondering here what the handle is made from? It may be the distortion in the pic, but it almost looks flat on the inside of the ring. Also curious if its solid or tube of some sort?
    WY...armpit of U.S.A.
    636
    Quote Originally Posted by tom37 View Post
    While waiting for a reply from the original poster I'll add that the handle appears to be schedule 40 pipe. The flat on the inside perimeter is due to using a flat die on the ring roller. With the pressure needed to form the curvature you would expect deformation in the pipe. To alleviate the flat just use a round sectional die instead.
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
    Dec 2008
    Scotland
    7
    Default ring roller
    Hi lads,the slots,first l drilled the hole and l milled the slot out,this was taking ages so the second side l just went down it with a cutting disk.
    The handle is a length of 1"dia conduit,yes its flat on one side because off the roller pressing it but this was in my favour so it was ok,my plan is to get another 3 track pins and m/c a radius and cut a square out on it so l can roll round and 1" box section,thats the plan anyway.
    cheers jack
    Aug 2004
    Milan Michigan
    1,418
    Good Job Bettlejac, I made a roller also, its not something I use every day but when you need it you need it.
    I just bid a looping crane system where 10 chain hoist just keep going around in an oval so I have to roll the electrical duct bars to follow the oval I beam.
    Heres a pic of my roller.
    Apr 2006
    San Diego
    375
    Thumbs up HEY! You found my ring roller!
    Dang. I wuz wondering where that thing went. I would have never thought to look in Scotland!
    Great job. I hope it works out for you.
    That's 1/4" x 12" I fed into mine. Yikes.
    Maxstar 200DX
    Maxstar 300DX
    Passport
    Spectrum 701
    LMSW-52 spot welder
