Results 11 to 14 of 14
    Nov 2005
    130
    I'm just a hobby guy that likes to fabricate.
    I've never run coolant, the saw came with it but I don't need that mess.
    I run the second fastest pulley and control the cut with the down feed.
    I think I'm on my 3rd blade. The first 2 taught me to loosen the belt.
    I bought the saw at least 5 years ago (Enco $450. free shipping) and have cut tons of steel with it.
    This saw is fine for my needs, I don't need anything fancier.
    Sep 2008
    Estevan, Sask
    111
    Here is a small tip for you for cutting wider pieces of flat bar etc. Put a bit of a spacer under the trailing edge of the material so the blade never cuts across the whole surface at the same time. The blade will only contact a small portion of the material thus keeping the teeth from loading up and breaking off.
    Nov 2005
    130
    Thanx Shep-
    I never thought of that - good idea.
    Oct 2008
    taxachussetts
    403
    Quote Originally Posted by Scarsman View Post
    Thanks. I think I will run down to Harbor freight and see what they have.
    i run a HF 64 1/2 blade and it works great i push it in the vertical position as hard as i dare wail I'm sitting on the bed and i haven't broke it yet. (witch amazes me as i thought the blade was a piece of crap) (bi-metal 10 tooth on sale $8 )
    TB 302
    dynasty 200sd
    spoolmatic 30a/wc24
    suitcase x-treme 12vs
    miller 211
    evolution rage 2
