Results 1 to 7 of 7
    hillsboro,OR
    45
    Default TIG Titanium and zirconium bend tests
    welp let me know what you guys think. It was the first time I have ever welded and im only 17 so please go easy on me.
    now to the procedure first thing was to prep the plates file down the bers on all sides then wire bush all sides next was wipe down the plate and filler rod with acetone. after that I set up my backing and trailing block purges . now with ti and zr you cant let eny carbon or oxygen into the weld pool thats why you use a purg backing and trailer. with this you can see that my welds are all silver color witch is good eny color is a no no! now there is some color on thies but it is not on the weld but on the parts where the Trailing shield did not cover. now if this was say arospace stuff that calls for no color so these would not pass but most of the time when you doing arospace work you are using a 100% arogon purge tank so that you dont have to worry about a Trailing shield not covering all off the plate that is above 700 degrees.
    zirconium face
    zirconium face
    zirconium root
    Millermatic 135
    Syncrowave 200 with coolmate 3
    Hypertherm powermax 30
    were I am when I am home
    http://i21.photobucket.com/albums/b2...5/IMG_7413.jpg
    hillsboro,OR
    45
    zirconium root
    Titanium face
    Titanium root
    Titanium face
    Millermatic 135
    Dec 2008
    CDB Land, TN
    135
    Is there something wrong with the welds?
    Looks like you did good, real good!!!
    Be safe
    Jeff
    Give more than you get and
    you will get more than ya need.
    This is true for the good and bad
    that life puts out.
    Chicago-ish
    282
    Would you mind reposting the first post without pictures so we can read it? Thanks.
    hillsboro,OR
    45
    Millermatic 135
    Aug 2004
    Milan Michigan
    1,814
    Correct me if I'm wrong but I thought your suppose to grind the test Pc. flat.
    Thats what I did back when I did my cert.
    We then put an acid to show where the weld was and that whwere it was bent.
    Thats some pricey material that your learning on.
    Last time I bought titanium it was approx. $ 116.00 a Lb. for the filler wire.
    Jan 2008
    In wal-mart
    460
    welding coupons are supposed to be ground flush, with the grinding marks going long ways across the coupons. I see one coupon looks like it opened up a little, but the picture is blurry, so I cant be sure. Next time grind them flush like I told you above, and then bend them. In every shop I've been in, if you bend out without grinding flush properly, you fail, no questions, but QA would of caught that and then instructed you to properly prepare the coupons. I was taught how to tig weld titanium by a Nasa certified welder in a machine shop called triangle of technology in pensacola florida, and when we welded titanium, we tig welded it in a 100% purged closed enviroment box structure. I learned allot from that guy, he was about as good as they come as well.
