Results 1 to 2 of 2
    Jun 2007
    Camden, SC
    156
    Question HH-210 with DP3035 Tomorrow
    I'll be ordering the HH-210 with DP3035 spool gun tomorrow morning. Does anyone have any idea if I can buy a regular 3035 spool gun extension kit (25' cable-extension kit) to use with the DP3035? I realize I'd have to extend it on the gun-end as opposed to the welder-end, but will it work?
    Clint Baxley
    Baxley Welding Service
    Rembert, SC 29128
    Oct 2005
    Bulverde, Tx
    1,244
    As far as I know, no, you can't. The DP spool gun uses a different set up for the connection. It may be possible with extensive change outs and modifications, but as a plug and play, no.
    I am very sure you will be quite happy with that setup. I have been using mine for over a year now and am still extremely pleased with the way it works. When I recieved the field test unit, I wasn't thinking it would be anywhere near as good as my MM210. It was a very pleasant surprise to see it not only was as good, but even better in many respects. Aluminum was one of the even better areas.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    HH210 & DP3035 spool gun
    Esab Multimaster 260
    Esab Heliarc 252 AC/DC
