Results 1 to 8 of 8
Thread: Granite Island
    732
    Default Granite Island
    I need to know your opinion. Would 2" 14 GA box tubing be sufficient to support a 44" piece of granite for a kitchen island? The island will be fully supported similar to the structure of a welding table. Any thoughts would be greatly appreciated.
    Thanks,
    Sep 2006
    Abilene, Texas
    639
    I wouldn't hesitate. The attached pic is a conference table that I built the frame for. It's 2x2x14 ga for the top frame and legs and 1.5x1.5x14 ga for the lower support. The top frame also has 2 pieces that run across the short way to support the granite. That granite top is about 4 ft x 6 ft. The table is rock steady. The table is located in the granite seller's showroom. BTW, the blue chairs have been replaced.
    Jim
    732
    Quote Originally Posted by Jim-TX View Post
    Thanks Jim....WOW that was fast!!
    732
    Very nice work I might add!!
    Aug 2004
    Milan Michigan
    1,811
    I think that would give you a good sturdy surface, No problem as long as you have good welds.
    My back ground is 20 years of doing this type of work, building and designing things.
    I would however design some leveling pads that screw into the bottom of the legs to keep it from wobbling.
    Portable Welder (or anyone else): On this kind of box frame design, what methods do you use to get the legs parallel and cross members perpendicular to one another? Also, when tacking a leg to the cross members how do you keep a tack weld on one side from pulling (tilting) the leg when the weld cools? Any tips would be appreciated.
    MTBob
    ____________________________
    MM 251 w/Spool gun
    MM 135
    Evolution Cut Off saw
    Logan Lathe
    Clausing Mill
    Walker Turner Drill Press
    Feb 2008
    893
    Put diagonals on it to prevent racking. Otherwise, a failure mode like this may happen...
    http://www.youtube.com/watch?v=sEaqfpqLBK4
    Without diagonals, you are relying on every conection to be a moment connection, and this makes the welds between legs and the top horizontals a critical weld.
    Addition of one diagonal in each plane defines a rigid shape relying only on pinned connections.
    In the video above, the structure racked just a little bit from the impact and this overloaded every connection because they were not moment connections. Scale that down and imagine hitting your counter with a hand truck or maybe during a "heated family scuffle."
    Here's another failure due to lack of diagonal bracing or moment connections (you've got to have at least one)...
    http://www.youtube.com/watch?v=tAOVkKWNfdo
    Aug 2004
    Milan Michigan
    1,811
    Theres nothing complicated about this, Use a flat table and a square no other braces needed unless for temporary use.
    Just tack the unit together and keep checking things.
    The bottom of the legs will warp in slightly maybe an 1/8" at most.
    Use a bottle jack to spread them back out if its that criticle.
