Results 1 to 8 of 8
Thread: Granite Island
    Aug 2007
    674
    Default Granite Island
    I need to know your opinion. Would 2" 14 GA box tubing be sufficient to support a 44" piece of granite for a kitchen island? The island will be fully supported similar to the structure of a welding table. Any thoughts would be greatly appreciated.
    Thanks,
    Nick
    Sep 2006
    Abilene, Texas
    639
    I wouldn't hesitate. The attached pic is a conference table that I built the frame for. It's 2x2x14 ga for the top frame and legs and 1.5x1.5x14 ga for the lower support. The top frame also has 2 pieces that run across the short way to support the granite. That granite top is about 4 ft x 6 ft. The table is rock steady. The table is located in the granite seller's showroom. BTW, the blue chairs have been replaced.
    Jim
    Aug 2007
    674
    Quote Originally Posted by Jim-TX View Post
    Thanks Jim....WOW that was fast!!
    Aug 2007
    674
    Very nice work I might add!!
    Aug 2004
    Milan Michigan
    1,422
    I think that would give you a good sturdy surface, No problem as long as you have good welds.
    My back ground is 20 years of doing this type of work, building and designing things.
    I would however design some leveling pads that screw into the bottom of the legs to keep it from wobbling.
    Quote Originally Posted by Portable Welder View Post
    Portable Welder (or anyone else): On this kind of box frame design, what methods do you use to get the legs parallel and cross members perpendicular to one another? Also, when tacking a leg to the cross members how do you keep a tack weld on one side from pulling (tilting) the leg when the weld cools? Any tips would be appreciated.
    MTBob
    ____________________________
    MM 251 w/Spool gun
    MM 135
    Evolution Cut Off saw
    Logan Lathe
    Clausing Mill
    Walker Turner Drill Press
    Feb 2008
    835
    Put diagonals on it to prevent racking. Otherwise, a failure mode like this may happen...
    http://www.youtube.com/watch?v=sEaqfpqLBK4
    Without diagonals, you are relying on every conection to be a moment connection, and this makes the welds between legs and the top horizontals a critical weld.
    Addition of one diagonal in each plane defines a rigid shape relying only on pinned connections.
    In the video above, the structure racked just a little bit from the impact and this overloaded every connection because they were not moment connections. Scale that down and imagine hitting your counter with a hand truck or maybe during a "heated family scuffle."
    Here's another failure due to lack of diagonal bracing or moment connections (you've got to have at least one)...
    http://www.youtube.com/watch?v=tAOVkKWNfdo
    Equipped with red and blue... and red and green!
    Aug 2004
    Milan Michigan
    1,422
    Theres nothing complicated about this, Use a flat table and a square no other braces needed unless for temporary use.
    Just tack the unit together and keep checking things.
    The bottom of the legs will warp in slightly maybe an 1/8" at most.
    Use a bottle jack to spread them back out if its that criticle.
