Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Apr 2008
    171
    Default new jd tube notcher
    boughrt a new jd2 tube notcher its HD
    must be 30lbs
    Jan 2009
    6
    ive used one like it u wont have 2 clamp it down .real nice
    Jul 2006
    alaska
    181
    Wow! That looks really solid. I bought the aluminum one and the jd m3 bender, havent seen it yet, but am excited to. Have you checked out their free bender software? I downloaded it and it looks pretty good. Havent put it to practicle use yet, but it looks promising. Make the mistake on the computer and not expensive material.
    29
    Quote Originally Posted by BC Iron works View Post
    must be 30lbs
    hope you like the hole saw notchers!, i bought a notcher made by Williams Lowbuck. its a mechanical notcher, no hole saw. its the best notcher ever made! i can notch the end of a tube in under 30 secs. cost around 300 dollars.
    Apr 2008
    171
    the jd2 was $300.00
    Utah
    162
    That looks identical to my JMR and it has worked well for me for about 4 years now. Good solid tool. Mike.
    3,936
    Thats got to be the cleanest looking John Deer in the background of the 3rd pic i have ever seen. The notcher's cool too...Bob
    Baldwin, NY
    275
    I agree It must be brand new...lol no way it would stay that clean here, even after I CLEANED it
    Voigt Precision Welding, Inc.
    Miller Dynasty 200 DX, Miller Syncrowave 250, MillerMatic 252, Hypertherm Powermax 45, Auto Arc Trailpower 8000,272+187 lb Peter Wright anvil, 120 lb Fisher-norris, and more! Buffalo drill press, Grizzly Horiz. Bandsaw, Edwards shear, Barth Shear, bantam mechanical ironworker, Hopkins fly press, Doall Bandsaw, brown and sharpe surface grinder.
    2007 Silverado 2500HD (tow vehicle)
    2000 Camaro SS (Race car)
    Jan 2009
    9
    what kind of drill is needed to use it
    29
    Quote Originally Posted by got wide View Post
    Come on! check out the Tubing nothcer from Williams Lowbuck! you dont need a drill! i can notch a tube in under 30 seconds, no drill, no drill bits, no sparks, or cutting fluid.
    The Williams Lowbuck notcher is the only notcher i will ever use again, it has a case hardened jaw that takes a bite out of the steel. all you need is a 4 foot steel handle to operate notcher.
