Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Aug 2006
    Raymore Missouri
    1,920
    Hey Vice.........is acid core bad and why? I suggested that off the top of my head..........................Nick
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Aug 2004
    Milan Michigan
    1,834
    Monte, I'm with you, Thats what I would have suggested.
    Not that I do a ton of radiator work, actually very seldom once every couple of years for the last 20 years.
    I also use my map gas torch usually.
    Nov 2007
    10
    Default Thanks to all
    I finally got a chance to solder the bracket and it worked great. Thanks to all. I appreciate it.
  4. #14
    Feb 2009
    1
    Well try to consult it to a mechanic for good result... Or just search in copper manufacturer to get some tips about welding bracket on copper radiator...
    __________________
    Copper Sinks
