Results 1 to 10 of 14
    Nov 2007
    10
    Default Welding bracket on copper radiator
    The mounting flange on the side of my 69 Camaro has detached itself from the radiator. Has anyone out there had any experience re-attaching the flange? Can it be welded? The bracket is steel and the side tank of the radiator is copper. Thanks for any help that might be out there.
    East Tennessee
    141
    It's soldered on. There's a dimple or raised place on each side plate at the tank. hook a light spring, or bungee cord in each of these (use a piece of wire on the side that's loose, so the bungee cord doesn't melt) this will pull the sides together as the solder melts it'll settle right into the right position then heat the side that is loose with a torch. You may need to add a little solder, but there's usually enough to reattach the side already there.
    If it's been broken a while, or it's dirty, you may need to pull the side back a little, clean & re-tin both pieces, then re-solder as above...
    HTH
    Cya Frank
    Professional Auto Mechanic since 1974
    My own shop since 1981
    Cya Frank
    Nov 2007
    10
    Smile
    Cya,
    Thanks for the great information. I really do appreciate it. I'll let you know how it turns out. Thanks again, Bill (z302)
    I believe you will want to use silver solder.
    Oklahoma
    701
    Quote Originally Posted by Jeepnford View Post
    No.
    Griff
    Raymore Missouri
    1,920
    No what..........
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Nov 2007
    10
    Is there a special solder to use? I'm getting ready to do this tonight after work. Thanks
    Nov 2007
    10
    One more thing, I found out that the side tanks on this radiator are brass not copper.
    Raymore Missouri
    1,920
    I would think a soft solder with low melt temp is called for. You could probably use acid core solder. Clean your parts well and tin each part. Then hold it in place and heat untill the solder starts to flow and remove heat without disturbing the part. Be careful not to use too much heat or you'll melt other joints as well. A good sized soldering iron should work. Leave the o/a alone. Clean the residue off afterwards.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    Jan 2008
    VA
    298
    I use 95/5 plumbing solder it is a bit harder than 50/50 but in the same heat range. Clean and coat with non acid flux.
