Results 1 to 10 of 12
    Jan 2009
    6
    Default MM200 Input Voltage Taps
    Hello,
    I just picked up a MM200 and want to set up the input voltage for 230V.
    However the Owners Manual says: Compare the position of the jumper links on the input terminal board to the voltage link arrangement shown on the voltage input label.
    I have no label. I think it fell off.
    Anyone have a picture of the label?
    Or, know the correct taps for 230V?
    Thanks,
    Gif
    Oct 2007
    2,949
    Default Mm 200
    jeepgif: Is it possible that you have a 230V model, and don't need to be concerned?
    Just a thought why there may be no label.
    Dave
    "Bonne journe'e mes amis"
    Jan 2009
    6
    ok, then why the two taps and jumper?
    Thanks,
    Gif
    Dec 2008
    CDB Land, TN
    135
    Have you tried to use this place.
    http://www.millerwelds.com/service/ownersmanuals.php
    Page 38 of the manual, circuit diagram number SB-119 327-A
    The red arrow is the volt select.
    It looks like it is set to 230 volt
    Be safe
    Jeff
    Give more than you get and
    you will get more than ya need.
    This is true for the good and bad
    that life puts out.
    May 2007
    Dallas, Texas
    323
    Quote Originally Posted by jeepgif View Post
    Thanks,
    Gif
    Gif,
    Welcome to the forum.
    I'm guessing you have a 1981 model MM200. Serial # should start with JB.
    You probably have a 200/230v or 230/460v input. Look on the face plate. If you have a 230/460v input, you really can't go wrong connecting it to a 230v source. You'll know when you have the jumper set to 460v. The fan will barely turn on when you power it up.
    Jumper settings are in the center of the very first pic. Kind of red color and three brass screws and nuts.
    Jumper settings:
    200/230v input:
    200v = jumper left and middle
    230v = jumper middle and right
    230/460v input:
    230v = jumper left and middle
    460v = jumper middle and right
    It is common for the paper label in power input to fall off.
    PM me your address and I'll email you a manual.
    Charles
    Millermatic Passport Plus
    Millermatic 200
    Millermatic 350P with Python
    XMT 304 /w S-64 feeder and 12VS
    Dynasty 300 DX
    Thermal Arc 400 MST
    Premier Power Welder for my trail junk.
    Jan 2009
    6
    Quote Originally Posted by redintn View Post
    Thanks,
    I do have a copy of the PDF. That is where I got the instructions I referred to in my first post.
    How did you conclude that mine was set up for 230v from the circuit diagram number SB-119 327-A? I do not see a connector identifier called out.
    Thanks,
    Gif
    Jan 2009
    6
    Quote Originally Posted by crawler View Post
    Gif,
    Jumper settings:
    200/230v input:
    230/460v input:
    Charles
    Yes, mine is rated for 200/230 input voltage as marked on the front.
    So I should be all set as is. (230v = jumper middle and right)
    Thanks,
    Gif
    Edit: SER # HK343965
    Found the settings in the "older" model Manual.
    May 2007
    Dallas, Texas
    323
    Thanks,
    Gif
    Gif,
    Your settings are correct. Let me know how it welds. Those old MM200 welders had industrial feeder size feed motors. Very heavy duty.
    Your welder must be one of the very first MM200 made. 1979 model.
    Charles
    Millermatic 200
    Dynasty 300 DX
    Thermal Arc 400 MST
    A very clean looking machine .
    for being that old
    They were a sweet welding machine.
    Good luck with her
    Rich
    Love the power of Blue
    Millermatic 200
    Sync 200
    Lots of Tools!
    Jan 2009
    6
    Gif,
    Charles
    It might be old, but it is in great shape!
    Wish I could say the same for me.... (round is a shape; right!?)
    I burned some 1/4 plate, exhaust scrap, and some 5/8 plate I had lying around. So far so good.
    I am used to a MM35, so this machine feels familiar. However I can tell the power difference in this machine. It has a much deeper tone on the heavier stuff.
    MM200
