Hello,
I just picked up a MM200 and want to set up the input voltage for 230V.
However the Owners Manual says: Compare the position of the jumper links on the input terminal board to the voltage link arrangement shown on the voltage input label.
I have no label. I think it fell off.
Anyone have a picture of the label?
Or, know the correct taps for 230V?
Thanks,
Gif
Results 1 to 10 of 12
Thread: MM200 Input Voltage Taps
01-27-2009, 05:52 PM #1
01-27-2009, 06:49 PM #2
- Oct 2007
- 2,949
Mm 200
jeepgif: Is it possible that you have a 230V model, and don't need to be concerned?
Just a thought why there may be no label.
Dave"Bonne journe'e mes amis"
01-27-2009, 07:12 PM #3
ok, then why the two taps and jumper?
Thanks,
Gif
01-27-2009, 07:58 PM #4
Have you tried to use this place.
http://www.millerwelds.com/service/ownersmanuals.php
Page 38 of the manual, circuit diagram number SB-119 327-A
The red arrow is the volt select.
It looks like it is set to 230 voltBe safe
Jeff
Give more than you get and
you will get more than ya need.
This is true for the good and bad
that life puts out.
01-27-2009, 08:03 PM #5
Gif,
Welcome to the forum.
I'm guessing you have a 1981 model MM200. Serial # should start with JB.
You probably have a 200/230v or 230/460v input. Look on the face plate. If you have a 230/460v input, you really can't go wrong connecting it to a 230v source. You'll know when you have the jumper set to 460v. The fan will barely turn on when you power it up.
Jumper settings are in the center of the very first pic. Kind of red color and three brass screws and nuts.
Jumper settings:
200/230v input:
200v = jumper left and middle
230v = jumper middle and right
230/460v input:
230v = jumper left and middle
460v = jumper middle and right
It is common for the paper label in power input to fall off.
PM me your address and I'll email you a manual.
CharlesLast edited by crawler; 01-27-2009 at 08:06 PM.
Millermatic Passport Plus
Millermatic 200
Millermatic 350P with Python
XMT 304 /w S-64 feeder and 12VS
Dynasty 300 DX
Thermal Arc 400 MST
Premier Power Welder for my trail junk.
01-27-2009, 08:55 PM #6
01-27-2009, 09:04 PM #7
01-28-2009, 07:48 AM #8
Millermatic 200
Dynasty 300 DX
Thermal Arc 400 MST
01-28-2009, 12:04 PM #9
A very clean looking machine .
for being that old
They were a sweet welding machine.
Good luck with her
Rich
Love the power of Blue
Millermatic 200
Sync 200
Lots of Tools!
01-28-2009, 06:22 PM #10
It might be old, but it is in great shape!
Wish I could say the same for me.... (round is a shape; right!?)
I burned some 1/4 plate, exhaust scrap, and some 5/8 plate I had lying around. So far so good.
I am used to a MM35, so this machine feels familiar. However I can tell the power difference in this machine. It has a much deeper tone on the heavier stuff.
MM200
