    Jul 2008
    East Tennessee
    615
    Default Lincoln Weld Pak 100
    I've got a buddy thats gonna let me have one of these for $75 but it's not set-up for gas yet . Does anyone know what all the kit consist of to put gas on it and can I possibly buy the individual pieces as I already have a regulator and gas hose etc. ? I've seen the kits on flea bay for around $120 but hate to pay for stuff I already have .
    Jul 2008
    Delhi, Ontario:
    1,974
    Thumbs up Lincoln Weld-Pac 100 ??
    Quote Originally Posted by Showdog75 View Post
    Showdog, Hi;
    I DO NOT Think the Kit contains the Regulator or Hose,
    As far as I know it would be the internal Gas Solinoid(spelling)
    and not what you already have !!
    ................ Norm :
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
    Jan 2009
    6
    Default weldpack 100
    look at homedepo kit has all you need but the tank $100.oo. good luck I love mine.
    2,910
    http://www.mylincolnelectric.com/Cat...et.aspx?p=7115
    The Kit does come with the Reg, liner etc.
    Lincoln probably has the Solenoid as a part - give them a call.
    Probably just easier to buy the Kit though.
    8,019
    Buy the kit, buy it online, or through a Lincoln warranty repair center, not from a distributor.
    2,949
    Default K610-1 MIG Conversion Kit
    www.weldingsupply.com has them for $120.00, maybe one could be found cheaper? Comes with the solenoid and the rest of the needed parts.
    Dave
    "Bonne journe'e mes amis"
    Jun 2006
    Maine
    732
    ok, I actually have a WP100 with the conversion.... the kit comes with the gas hose (solenoid to whip socket), gas solenoid, tank hose, regulator (NOT a ball type flowmeter), and if memory serves, a small wiring harness.
    oh yeah, and the gas nozzle for the gun....
    Bobcat 225NT
    Cutmaster 52
    Lincoln Weld-Pak 100 buzz box
    Caterpillar TH63
    '07 Kawasaki ZZR600
    Jul 2008
    Delhi, Ontario:
    1,974
    Default WP 100 Kit !
    Quote Originally Posted by nfinch86 View Post
    Showdog, Hi;
    Showdog, Sorry Man, I Was Wrong !!
    ........ Norm :
    - LN-25 Wire Feeder
    - Spoolgun.
    - DeWalt Chop Saw .
    The regulator which came with the kit for my Weldpac 100 only had a gauge for the tank pressure. There was no gauge to show flow and no adjustment for that matter. I replaced it with a good flow meter (floating ball type) with adjustable flow and even though I no longer have a Weldpac 100 I still use the flow meter that I originally purchased to replace that one. I did pass the single gauge, fixed flow regulator on to the purchaser of the Weldpac 100. I did consider that regulator good backup, in case something happened to my flow meter though.
    Larry
    "I feel for the man who can only spell a word one way"......Mark Twain
    Lincoln AC225-S (OLD/Copper Wound)
    Lincoln Weldpac 100
    Miller Matic 180 (auto set)
    Miller Spool gun 100
    Miller Spectrum 375 Extreme
    Victor Super Range II
