Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
    Jul 2006
    23
    Angry Welding, hydrotesting a compressor tank
    I purchased a compressor recently. It is a Speedaire, 80 gallon compressor with 7.5 HP motor and 80 gallon tank.
    Based upon first impressions, the motor and pump run fine. However, when bringing the tank up to pressure, I heard a hissing noise at about 140 PSI, and realized that there is a hairline crack in the tank, near a 2" long weld attaching the engine/pump mounting platform to the tank.
    The crack does NOT track the heat affected zone of the original weld, in fact it is perpendicular to it.
    Here the "=" signs denote the HAZ, and "\" signs denote the crack.
    In any case, when I saw this happen, I almost dirtied my pants and immediately relieved the compressor of pressure.
    I am not yet sure what was the cause of this crack in the first place. I will try to find what I can.
    My question, obviously, concerns my repair options. I do weld and have some experience with both TIG, as well as with 7018.
    But, I can hardly think of any welding where more is at stake than here, due to pressure. So, I see the following options:
    1) Take off motor and pump, cut holes in the tank and throw it away, look for another tank.
    2) Repair the tank by welding and hydrotest.
    Considering option 2, the first question concerns welding. How would you weld? How do you identify where the crack ends? Would you drill relief holes at ends of the crack?
    The second question is about hydrotesting. I was thinking about something simple, such as replace tha gauge with a 400 PSI gauge, close off all openings besides one, fill tank with water, connect to a hydraulic pump or grease gun, and bring pressure to 400 PSI (the tank supports 200 PSI) and look for leaks.
    This is very time consuming and I would like to know how likely would it be that I would make some very bad mistake.
    Jun 2004
    nj
    204
    This comes up quite often, and my answer is always the same: Unless the tank is something really special (and this isn't), scrap it. It isn't worth the risk fixing it. New tanks are cheap. The crack you are describing is due to fatigue from vibration and the stress concentration at the mount point (quite common, by the way). Likely to show up elsewhere as well in the near future, and my show with undesirable manifestations. The tank is worn out. There is no practical (ie: less expensive than a new tank) way to detect and repair these flaws before they open up for most people.
    I would suggest a replacement tank. Make up a frame to support the compressor rather than mounting to the new tank. Much better life that way, if you keep the tank drained of moisture. DO NOT weld mounts for the compressor to the new tank. If you must mount the pump directly on the tank, find a tank manufactured for the purpose, with the loading considered in the design.
    As a side note, in most places in the US and Canada, it is not legal to repair the tank yourself. It must be done by an authorized shop (Natn'l board "R" stamp holder, or equivalent). Non-commercial users can get away with it, but if there is a failure, your insurance probably won't cover any damage or injury.
    Traer, IA
    317
    Unhappy Ouch....Trouble brewin'
    I'd choose option #1
    I don't weld for a living so I'm by no means an expert, but I know several people who do weld for a living (my Dad mainly - Ok so he retired a few years ago at 71yrs young) and I can't think of one who would try to repair it. I do know some farmers and so called weldors who have tried repairing tanks, one of which spent 3 days in the hospital after a portable tank litterally got wrapped around his head (you could see where his nose, chin, and forehead are in the tank). The tank busted loose at about 90psi. I would have to beleive that if it is cracked in one spot, there's another one coming. I'm sure it could be fixed by someone that is willing to take a chance, but I hope like heck that no one is by it when it decides to let loose. I've seen the outcome of that, and trust me it aint pretty. Good 'ole flathead (his nickname even before the 'accident') kept that old tank as a stark reminder to the power of compressed air. Me, being the good friend and in general a smart A$$, bought him a new air tank after getting home from the hospital. That was probably 7 years ago - he still won't fill it.
    For what it's worth - If you decide to scrap it, That is a good idea to cut holes in it so someone doesnt see it at the scrap yard, curb, or whatever and decide to try using it....
    Dec 2008
    CDB Land, TN
    135
    As others have said "dont fix it"
    Dont cut holes in it!!!
    Cut in in half long ways.
    Make a grill or smoker.
    A parts washer, Large turkey fryer.
    But dont scrape it use it for a project.
    Lay the 2 halves a their side and a la penutbutter sandwich, a beer tub.
    The idears are coming fast. LOL
    Be safe
    Jeff
    Give more than you get and
    you will get more than ya need.
    This is true for the good and bad
    that life puts out.
    Cornwall, Ontario
    9
    I agree with everyone. I had that happen to a little compressor I kept in the welding truck. I think I'm gonna cut it in half and make two flower pots.
    Nov 2007
    Bay area California
    5
    Default Compressor Tank
    If it were mine, I would break it down, (motor and Compressor), cut the motor base off the tank (I'd use a cut-off wheel) leaving about 1/4" on the tank to weld it back on. Inspect the tank for more cracks, buff off the paint from the crack area, degrease it (using a non flammable degreaser) V out the crack slightly, preheat the base metal (90-150 degrees) Propane torch is fine, Tig or Mig the crack, clean-up the welded area, Fill it with a water hose (hydro test) most water systems are around 60-80psi. If all is good, weld the base back on the tank and put it back in service. You wouldn't believe the cracks I've fixed in the area Refineries and the pressure and temperature they operate at.
    3,953
    Quote Originally Posted by the_croz View Post
    If it was mine i would scrap it.
    Wouldn't the proper hydro be more than the pressure it would run at? I also work in a refinery and the hydro's are always more than the service the vessel would see on a normal operating run. Plus they always have someone to sign off on everything. I would think if he fixes the tank and something happens down the road a few years he would be liable or injured. Just my .02...Bob
    Aug 2004
    Milan Michigan
    1,837
    I have fixed a few compressor tanks in my life time and I have never seen a failure where the tank exploded like a granaede.
    Every time I have seen a failure it was nothing more than a split and the air bled out.
    I also have a few friends in the portable welding industry and none of them have seen a tank blow into peices like a bomb that many of you suggest.
    Keep in mind I'm talking about compressor tanks, usually 2'-3' in dia. max.
    I could see a large dia. tank having a big split that if you were standing near the split when it occurres that you could get hit by the splitting metal as it flares out.
    Also keep in mind that I am talking about a air compressor tank that typically holds not more than 175 Psi.
    Not a 3,000 psi tank.
    I would like to hear some feed back as to what the failures were on the air compressor tank failures that you vetrans have seen.
    Did the tank slightly split open and the air leak out as I have always seen or did the tank break into peices throwing schrapnal.
    Raymore Missouri
    1,920
    Weld 4 fins on one end, paint it OD, then dig a hole deep enough for about 1/3. Tell people it's an unexploded bomb.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Jun 2004
    nj
    204
    Not common, but they do let go: http://www.railpictures.net/viewphoto.php?id=176187
    Most common failures I have seen would probably be pinholes from rust, followed by fatigue cracks near mounts. Neither is worth repair, as both indicate that the tank is near the end of its life and problems will recur, unless the tank is something really special (odd size, part of a machine and it can't be replaced, etc)
