Results 1 to 10 of 14
    Apr 2008
    BC, Canada
    45
    Default Trailer Question
    I want to build a trailer for two quads. What I am wondering is which way should the deck stringers go? I am told that from the left side to the right side is the way to go (Pic1). I have been known to go overboard when building stuff, a common problem with steel burners I think, but to me running them length wise (Pic2) would give me a more rigid deck, keeping in mind the axle will be the fulcrum. The deck is going to be 10' by 5' with the axle 6" inches to the rear of center.
    Any help would be great, thanks.
    Feb 2008
    North of Phila. PA
    404
    Not quite sure how running the structure lengthwise would give you a stiffer deck myself. I'll assume (you know what they say about that), that your axels will mount to the outer rails. That being the case those members will determine the lengthwise stiffness. If they are the same on both designs they should bow about the same "in theory", regardless if the load transfers from the sides as in pict one (assuming the trailer's evenly loaded) or from the ends in pict 2. Cross stiffness would come from depth of the members and how they join to the load bearing rails. In this case I would think that pict 1 with more cross rails would give you a stiffer floor in twist. Almost every trailer/ truck bed I can think of uses a design like pict 1.
    Think about how you plan to deck a 5X10 trailer. If you use plywood you either need a 5'wide or 10' long sheet in pict 2. It's available but costly. Most landscape/equip. trailers I see use a design like pict 1. The cut down 4x8 sheets of ply or sheet steel, fall on a crossrail or the 2x's run length ways front to back and sit on all the cross rails.
    Good luck.
    Jan 2009
    13
    What size are the quads no.one? Do you want to haul them side by side or one behind the other? How heavy gvwr are you looking for?
    Vero Beach, fl.
    761
    The crossmembers must be placed from side to side to give the trailer any strength and rigidity. Running the crossmembers lengthwise will result in a very weak and unsafe trailer.
    Jan 2009
    13
    I agree the best way is to have the cross members running side to side, but i have a 7 ton trailer with three longitudinal frame members and no cross members.
    Feb 2008
    Guam
    177
    Default You need both
    You need both, also your deck needs to be securely attached for additional stiffness.
    Jun 2006
    Maine
    732
    if you've got big 4x4 quads like a Grizzly, I'm not sure both are going to fit on a 5x10.
    On my Big Tex 3500# 5X10 (which I had a hard time trying down 2 sport bikes on), the stringers run between the side rails, the deck is 2X8, screwed to each of the stringers. Since the deck has rotted out, I'm seriously considering redecking mine with AL diamond plate.
    this going to be a flat deck trailer or have sides?
    Bobcat 225NT
    Cutmaster 52
    Lincoln Weld-Pak 100 buzz box
    Caterpillar TH63
    '07 Kawasaki ZZR600
    Apr 2008
    BC, Canada
    45
    Default Thanks guys
    Thanks for the information.
    Looks like from side to side is the winner. I didn't put them in the pics but I am going to weld in stiffeners between the stringers.
    Thanks again, when it's done I'll post pics.
    Sep 2006
    Abilene, Texas
    639
    Listen to dabar39 when building trailers. He's built one or two.
    Jim
    Here's a link to my trailer project I did a couple years ago.
    Thought it might help you along with your project.
    http://www.millerwelds.com/resources...railer+project
    Good luck.
    Andy
