Results 1 to 7 of 7
    Aug 2004
    LI, NY
    230
    Default Mig wire for hard facing
    I was asked to hardface the side of some buckets on a front loader. I can do the job indoors and would like to use a mig to save some time. my machine will only hold 11# spools or smaller what wire would you recommend?
    Dan
    Lincoln SP170T
    ESAB 875 Plasma
    Smith oxy set
    pulsed mig is next...
    Long Island Cummins Ram Owners Club
    2,949
    Default Hard Facing Flux Core
    Dan: You may be out of luck. I'm looking in Lincoln's book, and 25# spool looks like as small as they go. Keep in mind, most of these wires are 5/64" and larger, so you need a big gun. There are some in .045, but again, 25# spool. Some of these are gas-shielded wires. You can visit Lincoln's website, look under consumables/hardfacing and check them all out.
    Hope this helps
    Dave
    There is one, Lincore 60-G "Severe Abrasion" that comes in .045, in 10# spools, and is gas shielded. May be your best bet.
    "Bonne journe'e mes amis"
    2,949
    Talking Hardfacing Wire; Part II
    Spcl: Forgot about other brands! I just looked in my RAM Catalogue, and they have .035, .045 sizes in 10#/8" spools with 2" hub. 3 different flavors, 3 different prices. visit www.RamWeldingSupply.com
    Thanky for the info
    Dave
    Feb 2008
    893
    Hardfacing electrode is high in Manganese. Don't let the lack of smoke trick you into filling your workspace with Manganese fumes.
    Deltaville, VA
    2,239
    Dan,
    I'd have to ask the question about whether we're talking about a "front loader" or the front loader bucket on a conventional tractor.
    If you're talking about a "front loader" as in heavy construction equipment, I'd have to question whether you've got enough machine (170 Mig) to do the job correctly. When I think of hardfacing heavy construction equipment, the first thing that comes to my mind is spray transfer. Hardfacing, if not burned in, will not hold up.
    Just my .02.
    Oct 2008
    89
    A couple of other things to not when hardfacing with wire feed, some of them contain chromium -very carcinogenic- make sure you have excellent ventilation. Also the wire is generally quite soft (at least the stuff I used was), and nested quite easily in our Miller 350. Look into a 10' whip with a teflon liner, or a push pull gun.
    2,949
    Default "Good Eye, Sundown"
    Dan,
    Just my .02.
    I read right over that one (long night), I just checked my hardface electrode catalogue, and his Dynasty can handle most of the rods (MM, ME, MI, BU).
    Dave
