Page 1 of 3 123 LastLast
Results 1 to 10 of 28
    Nov 2008
    Kansas City Metro
    387
    Default A new hitch on an old Ford
    It seems that my trailer is getting heavier and heavier. So I decided that it was time for a real hitch. I used 3/8" bent plate with a 3" hole for the 3"x1/4" square tube to fit thru. I used 1/4" plate to beef up the area where the receiver tube attached to the 3", front and back. There is 3 grade 8 1/2" bolts on each side.
    Sorry folks I forgot to get the camera until it was pretty well put together.
    Well its gona take one more post to get the rest of the pics.
    Stickmate LX 235 AC / 160 DC.
    Clarke 180 EN Just in case
    Spectrum 375 X-Treme.
    Milwaukee 14" Chop Saw.
    4 x 6 Horizontal Band Saw.
    Projects and Misc Albums
    http://picasaweb.google.com/keesfriend Feel Free to Have a Look ( Just keep in mind I am an amateur )
    Nov 2008
    Kansas City Metro
    387
    As you can see I am not very good at making the transition on the corners, but I hope with practice I can catch on.
    I know the tube is sorta long but it made a great place for the jack while I was fitting the hitch to the frame.
    I marked up my cut lines last night and went to work on it this morning. Between the kids, the wife, and the neighbors I got picked up about dark.
    I ran the little 180 maxed out with .035 wire and co2. I was going to use 7018 but I tried a test piece, and after the destructive test it appeared that I was getting good penetration with the mig. So I ran with it.
    Oct 2007
    Cave Creek Az
    1,066
    Nice work! It looks like a good design that is safe and well thoughout. I would feel comfortable driving behind it.
    Jan 2007
    Rosetown, SK.
    520
    That looks nice & beefy. good job.
    252 Miller Mig
    180 Synchrowave
    R - 45 Milling Machine
    Kingston 1100 Lathe
    Miller 2050 Plasma Cutter
    southern California
    1,783
    Looks great, nice work.
    I would cut down the tube protruding forward so a spare tire can fit under the bed.
    Nov 2008
    Kansas City Metro
    387
    Thank you gentlemen I appreciate it. The average joe wouldn't have a clue what goes into most welding projects.
    I agree about the spare tire. I just have to come up with a good secure way to mount it again. When I got the truck it didn't have a spare and the carrier was trashed. I think it fell down while someone was driving maybe. I didn't measure it but there may be room for the rear side of the tire to set right on top of the receiver tube and then I can make some sort of a bracket for the front side.
    Jun 2009
    Tallahassee, FL
    67
    Thumbs up
    very nice work
    Millermatic140; Spectrum625; Bobcat250; Lincoln AC225; Bosch grinder
    May 2009
    27
    looks like you've got a good bumper there. how did you bend those plates where it mounts to the frame?
    May 2009
    Gulfport, Florida
    440
    Thumbs up Great job your hired.!!!!!!
    Looks like you did a real nice fabricating and welding job. How much tongue weight are you having to hold up. Reason I ask I only see one weak spot. But if you will have a 500 lbs or less you should be fine..
    Bob
    May 2009
    The Colorado Gas Patch
    185
    Default Round off those corners..
    Do yourself and every mechanic in the distant future a favor by rounding off those corners with a grinder then a flap disc.. Nice work just keep it safe for all of the people that work around it..
    Steve
    Bobcat 250EFI
    Millermatic 350P
    Hypertherm 1250
    A Bunch of tools
    And a forklift to move the heavy stuff with..
    Torchmate 2x2 CNC Plasma
    It's Miller Time - Get Back To Work!
