Results 1 to 8 of 8
Thread: What rod?
    Feb 2008
    flat , and lots of dirt
    123
    Default What rod?
    I do not do alot of stick, so I have a question:
    Building a ute trailer, out of 2 x 2 angle, what would be the best rod?
    I like 7018, but I believe that 6011 will be faster and penetrate better?
    I plan on abusing the trailer on unimproved roads.
    What do you think?
    SYNCROWAVE 200
    Atlas 618 lathe (vintage 1960) reconditioned DC
    Sioux 3/8 Pneumatic Reversible Drill
    Makita Everything else
    2400 square feet of Sanford and Son lookin shop space
    "Once the spoon flys, putting the pin back in won't solve anything"
    USA 15T, 15V
    www.myspace.com/blackbird455
    http://i100.photobucket.com/albums/m...5/DSC00356.jpg two cans, one welder
    Sep 2006
    Abilene, Texas
    639
    I'd use 7018 unless the angle is badly rusted. If it's rusted 6011 might be better, but cleaning the rust off and running 7018 would still be my choice.
    Jim
    Feb 2008
    123
    No rust, all new material.
    SYNCROWAVE 200
    USA 15T, 15V
    4,248
    You can use either one.
    Oct 2007
    2,949
    Default 2 x2 x ?
    Quote Originally Posted by Blackbird455 View Post
    What do you think?
    What's the material thickness? 2" bar size angle ranges from 1/8" - 3/8"
    A word of advice. You claimed your stick experience is limited (obvious by your question), so before you go building a trailer, that will suffer abuse, you might want to master some skills on a smaller, less portable project. Nothing worse than towing a trailer, and watching cross members, axles, and tongues fall off at 60 mph. Seriously, if you have to ask what rod to use, you probably don't have any business building one.
    The Syncro 200 can handle any rod you can"throw" at it.
    Dave
    "Bonne journe'e mes amis"
    Nov 2006
    Lake of the Ozarks MO
    3,447
    It depends on what you mean by faster...some 6011 welds look crappy enuff you will find yourself using a grinder on them to dress them up...good welds, just poor appearance. 7018 makes your work look better. Beads that you want to show off
    If I had to use 6011 I would prefer to go buy a mig welder instead.
    I have welded hundreds of pounds of 6011 working for people and despise the stuff myself.
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
    Oct 2007
    2,949
    Default 6011's
    Lincoln's Fleetweld 35's are much better than their Fleetweld 180's. Their 5P+ is also better than the 5P. I used some 6P+ today, (6010's) and I like how they run. A little smoother than the 5P+, kept a "tighter" weld pool and the "wagon tracks" grind out with little effort. Great hot passes.
    If you've never used the FW 35, try some, it might change your opinion.
    Just a thought.
    Dave
    Jul 2008
    Delhi, Ontario:
    1,950
    Thumbs up Welding Rods :
    Hi; Personally I'd stay clear of any E60 series Rods!!
    For My Money E7018 is the Best All Around Rod There Is !!
    Just My 2 cents !!
    ................ Norm :
    - Weldcraft WP26FV Tig Torch setup.
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Miller Econo Twin AC/DC High Freq.
    - Lincoln Power Mig 180C
    - Spoolgun.
    - Horizontal Steel Band Saw
    - DeWalt Chop Saw .
