Does anyone know the best (strongest) rod for welding 4130 Chromoly tubing. I am building mini sprint chassis.
Thanks,
Zeb
Results 1 to 10 of 36
01-17-2009, 06:45 PM #1
Best welding rod (tig) for welding 4130 chromoly tubing
01-17-2009, 08:26 PM #2
ER80S-D2
Lots of stuff here on that subject.
Andy
01-17-2009, 08:40 PM #3
Er80S-D2 is used in aircraft weldments that are heat treated, ER70S-2 is used for non heat treated. Of course standard practice involves post weld tempering or oven treating.
-Aaron"Better Metalworking Through Research"
Miller Dynasty 300DX
Miller Dynasty 200DX
Miller Spectrum 375 extreme
Miller Millermatic Passport
Miller Spot Welder
Motor-Guard stud welder
01-17-2009, 11:24 PM #4
- Nov 2007
- 184
Zeb,
You will not get agreement on the answer to your question.
Some use ER70 others use ER80. On the frame itself I doubt
you'll be able to do post weld heat treating.
I use ER80 and don't believe in the practice of torch annealing
the welded joints. I do use lowest heat needed an don't "hurry"
the weld along.
Opinions vary....do lots of reading and make your choice.
Will also mention that the Lincoln motorsports welding program
falls in the ER80 camp.
Dave P.
01-18-2009, 06:29 AM #5
- Jul 2008
- East Tennessee
- 609
Murf McKinney who builds most of the NHRA Top Fuel chassis uses ER80S D2 and doesn't stress relieve all the welds . If it's good enough for 8000-10000 horsepower I'd say it would work for you .
01-18-2009, 07:24 AM #6
ER80S-D2 is a higher strength steel filler that contains 1/2% of Molybdenum and more closely matches the strength of the 4130 than the ER70. You can stress relieve the weld joint if you wish but even some of the top drag chassis builders don't do it. Heat treating is only somewhat useful and relies on how much base metal is diluted with the filler. Normally, heat treating is done with 4130 filler and on thicker weldments. Keep your arc lengths as close to the joint as you can and do not overheat by using too much amperage but make sure the toes of the weld are tied in properly. With a mini-sprint chassis and the amount of triangulation that is used in the tube layout, you should be fine.
Like Dave said.
You will get many answers here....
Andy
01-18-2009, 05:26 PM #7
Miller Spot Welder
01-19-2009, 10:33 AM #8
- May 2007
- 539
You can use coat hangers...
The important point here is that on a race vehicle, the design is light weight, close to the limit of strength / failure. Some, but not a lot of "extra" safety margin.
Sooooo, what that means is, you race, you inspect, you race, you inspect, repeat until the frame is wore out...
Where folks get into trouble is they under design, never inspect, or forget that life cycle deal.
If you want to be competative, weight is an issue, having a vehicle break up under you or worse yet, not protect you when you really need it like when you tangle with a wall or 3 or 4 other vehicles.
Just kiddding about the coat hangers by the way.
01-20-2009, 03:57 PM #9
Miller Spot Welder
01-20-2009, 05:15 PM #10
- May 2007
- 539
I've got a closet full of them, first Grandpa's old clothes, then some of my pop's.
In years past we used them often on exhaust pipes with gas heat.
They actually work pretty good.
Back on subject, inspect, inspect and then clean and inspect. Think it is great the project is moving forward, no one teaches maintenance any more...
Hey Aaron, thought that would get a rise out of you
