Results 1 to 7 of 7
    Jan 2009
    Small town in SEKansas
    1
    Default Wrought Iron Basics
    I am a newby to this group.I am building a Wrought Iron fence to replace my wood fence. It has brick pillars every 13 feet and a wood support in the middle of the gap. I plan to keep the brick pillars and replace the wood post in the middle with a 2x2 metal. The basic question is will I need to put in some sort of expansion joint in the horizontal run. I cant see the brick pillars giving much and the run will be bolted to the pillars.Thanks, HLAlexander
    Jul 2008
    Delhi, Ontario:
    1,963
    Question Expansion ??
    Quote Originally Posted by HLAlexander View Post
    Hi and Welcome; What Expansion are you talking about, up & down ??
    If so just slot the connection to the pillers, to allow for movement !
    ........... Norm : PS. Where are you located ??
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
    alabama
    746
    I believe he means between the two colums. I dont feel it would be necessary but if you feel the need, use something like a rubber grummet.
    2, XMT's 350 cc/cv
    1, XMT 350 vs
    1, TRAILBLAZER 302
    1, MILLER DVI
    1, PASSPORT PLUS
    1, DYNASTY 200 DX
    1, MAXSTAR 150 STL
    1, HOBART CHAMP
    1, HF-251 BOX
    1, S-74d
    1, S-75DXA
    2, 12-RC SUITCASES
    2, 30 A spoolguns
    Sep 2007
    Medford MA
    538
    Carbon steel has a coefficient of expansion of 0.0000065/degF
    which means that for each degree-F of temperature change,
    the steel will increase in length by 0.0000065. One foot
    would become 1.0000065' and so on.
    You don't say where you are. But if we assume a maximum temperature
    swing, winter-to-summer, of 150 degrees f, that means that
    the steel will expand/contract by 0.0000065 * 150 which comes
    to 0.001' per foot -- so if you've got 13', the difference in
    length from coldest to warmest would be 0.013', or about
    0.15". As Norm said, you could use a slotted hole (or even
    just a somewhat larger hole) for the bolts and you should
    be fine.
    Frank
    Oct 2007
    Cave Creek Az
    955
    Nice work FJK! About the expansion joint no. In fact, if you are using steel verticals in there as well I wouldn't even use 2x2. You could use as small as 1 inch .065 square tube. I tend to use 1.25 or 1.5 square .065 tubing just for a stockier feel to it though.
    Sep 2007
    Medford MA
    538
    Quote Originally Posted by walker View Post
    Nice work FJK!
    Personally, I would think that having one or two verticals that are bigger
    than the ones in the main panels and looking like they are real posts
    would look better -- even if they are not needed for structural reasons.
    Might even want to go bigger than 2x2 (if the budget allows), maybe
    put a finial of some kin on top.
    But then, some people say that my artistic sense is located in my ...
    Actually, now that I think of it, the original poster might want to take
    an hour browsing through the King Metals catalog (it's on line at
    www.kingmetals.com). There are lots of good ideas, design hints,
    and so on in it.
    Let us know how it works out, and send pictures!
    Frank
    turbo38t Guest
    I'd say no. In all of the iron fence I ever did I never used expansion joints.......as a matter of fact I believe everything I ever made was cemented or bolted down and never had any issues. Dave
