Thread: Frame Fab Help
    Jan 2009
    Default Frame Fab Help
    I have to fab a frame for a small powder coating oven (about 20 feet long, 6 feet high, 6 feet wide) out of 2x2 square tubing. I made a rough drawing below of the side view and then below it the top view. From the side you can see that the legs are not attached to anything at the bottom. I was thinking the best way to go would be to build the whole thing upside down and then flip it. Any other ideas?
    Jul 2008
    Delhi, Ontario:
    1,950
    Question Small Oven ???
    Quote Originally Posted by nightfer View Post
    nightfer hi, & Welcome; First where are you doing this job??
    Do you have access to an overhead crane or a
    fork lift ??
    If you do I'd fab up the sections, six I presume ?
    Then assemble them, tack them in place( solid tacks )
    Brace the sections, and weld it up !!
    ............. Norm :
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - Horizontal Steel Band Saw
    - DeWalt Chop Saw .
    alabama
    718
    Build each side seperate,flat on the floor. Then stand the two sides up and put the roof members on.
    XMT 350 cc/cv
    XMT 350 vs
    TRAILBLAZER 302
    MILLER DVI
    PASSPORT PLUS
    DYNASTY 200 DX
    MAXSTAR 150 STL
    HOBART CHAMP
    HF-251 BOX
    12-RC SUITCASES
    12-VS SUITCASE
    1,567
    Build one side flat on floor or table then build second side on top of it. This way you don't have to measure or layout for the second side. Stand them up & connect them. Remember that this can get kinda heavy when your done. I would cut the top piece total length less 1/4" so you can cap each end with 1/8 plate. The four leg tubes would run from under the top & go to the floor & the bottom tube & two horizontal tubes would fit in between the legs. Short vertical tubes would be cut to fit in between each horizontal tube as needed.
    Sep 2006
    Abilene, Texas
    639
    Why does the oven have to set up off of the floor? My powdercoater has an oven that's 20x8x9 and sits on the concrete floor. That way he can push racks in and out. It seems like getting stuff in an oven 20 feet deep would be almost impossible if it's off the floor.
    Jim
