Results 11 to 16 of 16
    Feb 2006
    Northern CA, Shasta CO.
    144
    Looks one heck of a lot better than anything I've ever seen with a wooden handle on it!!! I'll bet it does what it's intended to do.
    You can buy, or make, tire chains for fork lift tires.
    JTMcC.
    Akron,Pa
    152
    looks pretty good. hope it works out ok for you
    Dylan
    RED BIRD WELDING
    "Experience is simply the name we give our mistakes"
    HH-140
    Crappy stick welder
    Victor supper range II
    Makita grinder
    more stuff i don't feel like listing.
    Jan 2011
    A few co's make them. There's one with a cool video - works great! ChinookForkPlow.com - yours is built like a tank though!
    Apr 2008
    Toronto, Ontario Canada
    11
    If this was mine I would add a bolt on cutting edge to the bottom. Other than that I like this.
    Millermatic 185 + Shopping cart .. cart
    Metabo 4 1/2" grinders.
    Milwaukee v18 cordless drills and jobsite radio!
    Nov 2009
    houston pa
    104
    someone already said it but if you hit something solid with that at speed somebody might get jacked up.
    youll probably need enough weight on the front of it to get it to go that it wont steer. atv chains work but make for a bumpy ride. studs work too but you have to be easy on the throttle or you just rip them out.
