Results 1 to 10 of 16
    Apr 2008
    BC, Canada
    45
    Default Forklift Snow Plow
    I made this for work. Got it finished in my spare time and now there isn't anymore snow. Let me know what you think. Pics aren't greatest but you'll get the idea.
    Thanks, Goon
    Jul 2008
    Delhi, Ontario:
    1,986
    Thumbs up Snow Plow :
    Quote Originally Posted by Cargoon View Post
    Thanks, Goon
    Cargoon, Hi; Looks Good, First what is holding it on to the Forks ??
    Second how did you make the Blade ??
    Where are you Located? Just Curious??
    ............ Norm :
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
    Sep 2008
    southwestern ohio
    272
    nice plow but I dont think a forklift would get enough traction to plow snow
    Lake of the Ozarks MO
    3,593
    Most forklifts I've been around would have gotten stuck on an ice cream cone. YMMV. It may be awsum....time will tell.
    Run it over to Seattle and try 'er out
    On the other hand if it doesn't work as expected you can drop it off at my shop and leave it
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Sep 2008
    southwestern ohio
    272
    if it were used on a skid loader it would probly work beter but in that case it would probly be better to just put a quick atach plate on to mount it directly.
    Mar 2008
    148
    Put about a ton behind the plow on the forks........Then I bet it will push snow.
    My forklifts get stuck on the least bit of snow without a load.
    RoyB
    Dartmouth, MA
    http://www.rvbprecision.com
    Millermatic 185 MIG
    Miller Diversion 165
    Purox W200 O/A
    Grizzly 9957 Mill
    Grizzly 4030 Metal Band Saw
    Grizzly 1050 Knife Belt Sander
    Jet 1236 Metal Lathe
    TP Blast Cabinet
    Nov 2007
    Saskatoon, Sask, Canada
    1,270
    If he puts some weight on the forks he might be ok as long as it's not too icy.
    Norm the forks go into what looks like a rectangular tube, then if you notice the two bolts in those tubes will go through a hole in the end of the fork. The forks likely bottom out against the blade but you need the bolts so the blade doesn't pull off when you back up and forget to raise it.
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
    Jun 2006
    Maine
    732
    Thanks, Goon
    Nice job, but I have two comments..... one, it looks like your blade is tipped a bit too far forward... and two, there's no blade or edge trip.... somebody's gonna get hurt... seriously.
    Bobcat 225NT
    Cutmaster 52
    Lincoln Weld-Pak 100 buzz box
    Caterpillar TH63
    '07 Kawasaki ZZR600
    Apr 2008
    BC, Canada
    45
    Default Thanks
    Thanks for all the comments. I have attatched some better pics withe some mods to it.
    In responce to:
    nfinch86 - 1. I have welded chain to the sleeves
    2. The blade was an old damaged reservoir from a locomotive
    3. Britich Columbia Canada (Best place on earth, especially if you like to pay taxes)
    Metalmltr - The plow is at the end of the forks so I can pick up a pallet with some brake shoe's or something on it for wieght.
    CWagner- The bolts do not go through the forks. The other two holes in the sleeve are to turn the blade, if you want to puch the snow to the left you put a pin in the hole on the right and the fork on that side can only go that far. Blade turns.
    Bretsk2500 - I put in bigger bolts so it doesn't lead forward to far anymore. I only had a 1 1/8" drill that was sharp enough to do all the holes. I will add a blade or edge strip, don't want any injuries.
    Thanks for all the comments guys.
    I wish I had pictures of our first forklift. It came with a bucket, a blade, two sets of forks. She was a real cream puff! The blade had a steel box built behind it on the forks with 1000# of weight in it. It would push snow, gravel (if you took small bites) and do a good job. Of course it was new in the early 1960's and only lifted 4000#. Your blade looks to me to be a bit far away from the fork mast. This will make it very sensitive to tipping the mast. Can be a bit of a surprise hitting a frozen lump with the mast tipped back too much!
    Good looking blade all the same.
