Results 11 to 20 of 40
    May 2008
    Belle Plaine Iowa
    270
    Good thoughts all. The squeaking in the case comes when the strap cracks and is annoying the other part of what it used to be. The truck came home. Ill get some pics.
    Miller AC/DC Thunderbolt 225
    Miller 180 w/Autoset
    Old cutting torch on LPG
    Mar 2007
    Oahu, Hawaii
    2,469
    Yeesh Paul, what derby are you entering in THAT thing!!! I guess you don't have any trouble running over deer!!!
    Flyingpig, stop running over deer!!
    If you do, do you guys take it home and eat it??? just curious, I have
    no clue, since we don't have em here...
    Can't wait to see pics of bumper and how you fix it!!!
    I'm not late...
    I'm just on Hawaiian Time
    May 2008
    Belle Plaine Iowa
    270
    Bert we have a great plenty of deer. How many do you want? You pay the freight. Yes we eat the ones that arent tore up.
    Heres the pics. The girly bumper, the broken bracket, the good bracket in place, and the bolt where the broken one was.
    Note how the bolt in the radiator support also holds an X brace. The bracket then is stressed unevenly by that brace. The bolt is at the end of the "L" rather than close in. I think it would work better if it was under the X brace but there isnt enough clearance.
    In my first post I said it was breaking at the bend. You see in the picture thats not the case. Thats just because I have CRS. The second break is right next to the weld from the first break.
  4. #14
    Mar 2007
    Oahu, Hawaii
    2,469
    YEESH! THAT'S A GIRLIE BUMPER??!!!
    LOOKS! HEAVY DUTY! Well, compared to Paul's, I guess it is!!!
    Looks like you can do heavier/thicker brackets or put more bracing like you mentioned, that's cool,
    but food for thought:
    If you do that, and make the bumper and bracing more stout, would you have a harder time fixing the radiator support when that gives way instead???? And anything else that you add attachments to???
    Never had deer meat. Wanna trade for some fish??
    I'm not late...
  5. #15
    May 2008
    Belle Plaine Iowa
    270
    Yeah that really is a lite duty bumper.
    I dont really want a heavier bracket but do need a stouter mount on the radiator side. Ive got it here on my desk and it measures 1 3/8 wide by 1/8 thick. It has 3/8 bolts instead of 5/16. The bracket is equally as girly as the bumper but the geometry on the one end is shyt. I think its a "universal" mount which means it works for everybody but me.
    What kind of fish?
  6. #16
    Mar 2007
    Oahu, Hawaii
    2,469
    Quote Originally Posted by Flyingpig View Post
    What kind of fish?
    usually easiest to get mahimahi. aku or ahi (lot more expensive) I haven't checked what has been biting recently! or, if you want it cheaper, I can get some roadkill also Dabar39 had some fish sent to him frozen, said it came frozen, no problem....If they send it to Japan and all over the U.S., should be fine!!!
    I'm not late...
  7. #17
    May 2008
    Belle Plaine Iowa
    270
    I aint never heard of any of those. That all sounds like something you go to the doctor for.
  8. #18
    Mar 2007
    Oahu, Hawaii
    2,469
    mahimahi is also know as dolphin fish in Mexico
    I'm not late...
  9. #19
    Aug 2008
    Krefeld, Germany
    18
    If space permits I would shorten the bracket and install an anti-vibration mount between bracket and radiator tray. That should solve the problems. Something has to give. A stronger bracket would just cause a different part to break.
    Steffen
    Krefeld, Germany
  10. #20
    Sep 2007
    Medford MA
    544
    chevy-man's mounts are a good idea. you can probably
    find something at www.mcmaster.com
    from the picture of the bracket you posted
    it looks like you'll have to rebuild the end with the
    long slotted hole -- it's broken through there :-)
    Where the bracket broke it looks like there might
    be some sharp corners -- notorious for being a
    stress point... when you rebuild the bracket
    consider adding more material to the end with
    the slot (like sistering boards in carpentry).
    and bringing the added material onto and along
    the long arm of the bracket a bit -- leaving most
    of the long arm the original thickness to do the
    flexing and vibration damping you mention earlier.
    Good luck, and keep us posted on how it goes
    And how bert's fish is!
    Frank
