I just bought a Miller Maxstar 150STL and tried welding with it today. I have a few questions, though.
I was using 3/32 6011 rods and welding on 1/8" steel plate.
When I was welding at 60A, I burned through the material at times. However, If I went down to ~55A, I couldn't get a continuous arc. It kept fizzling out on me. What would cause this, and what amperage should I be using for 1/8"?
While the arcs were fizzling out on me, The blue power light flashed on and off for a while. According to the manual, there was an error code. What would have caused that? On the hobart board, someone said it was due to a bad capacitor?
Then I tried welding some thinner metal (a coffee can, I'm not even sure this is weldable) and even at the lowest setting on the machine, it blew right through. Do I need smaller electrodes?
Results 1 to 8 of 8
Thread: Miller Maxstar 150 STL problems
07-28-2007, 02:48 PM #1
- Jul 2007
- 10
07-28-2007, 03:10 PM #2
- Jul 2007
- Batavia, NY
- 159
You mention the blue power light flashes....how many times does it flash? There are different trouble codes for differing ammount of flashes. If it flashes contuously then it may be an input power problem. What voltage are you running on? 115V, 230V?
As far as burning thru 1/8" material w/ 3/32" electrode: what polarity are you running on? Should be reverse polarity (electrode posative). Make sure that your process selector is in stick mode.
Also you mentioned burning thru a can in lowest setting. The lowest setting on the 150STL in stick mode is 20 amps. You should not even be able to light a 3/32" electrode at 20 amps.Rich Ferguson
Sales Technician
Jackson Welding Supply Co.
www.jacksonweldingsupply.com
07-28-2007, 06:32 PM #3
- Jul 2007
- 10
It is a constant flashing blue light. After it starts I can't get a weld started. The only way to stop it is to shut the unit off. Once I turn it back on it welds fine for a few minutes and then starts flashing again. I am running off of a 120V 20A circuit.
I noticed that the power cable and adapter I made gets warm, but I've never welded and checked the wire before so I don't know how warm is acceptable.
The process selector is in stick, and I was running DCEP. I also tried it on DCEN and didn't notice a change.
I put the amperage setting all the way to minimum and was able to easily strike the arc and burn a 1/4" wide path through the can.
07-30-2007, 07:44 AM #4
- Jul 2007
- Batavia, NY
- 159
Are you by any chance running off an extension cord? If so, try pluging the unit into the duplex without the extension cord. The extension cord you may be using may not have enough carrying capacity. That machine is supplied from the factory with a 115V 30A plug. Did you replace or adapt to the pug?
If you replaced it, check and make sure the plug is wired correctly. Sometimes when putting the cord cap back together one of the legs may drop off.
Now after checking the simple stuff your machine still does not function prperly you will have to take it to an authorized warranty repair facility for Miller. We have had a couple of units come back to us that need qualified techs to do the work. What we have mostly seen is off the input doard there is a 2 prong plug that burns up. This is a warranty repair providing the unit is still under warranty.Rich Ferguson
Sales Technician
07-30-2007, 08:42 AM #5
- Jul 2007
- 10
I checked everything you said, but it still acts up. I called Airgas and they have ordered a full capacitor upgrade kit for it.
I did make an adapter for the plug, but I also had an electrician check it out just to make sure.
07-30-2007, 08:44 AM #6
- Jul 2007
- Batavia, NY
- 159
Rich Ferguson
Sales Technician
07-31-2007, 01:49 PM #7
My Maxstar will go into the flashing blue mode from time to time - usually when I am starting an arc and stick the electrode. I chocked it up to a self protection mechanism. I'm running at 220v. Turn if off until it resets and it is back to normal. Tell me more about this capacitor upgrade kit.
As for burning a 1/4" wide path through a can at minimum - sounds to me like the Amperage pot is not having the correct effect and you're stuck at some higher amperage.
08-01-2007, 02:51 PM #8
- Jul 2007
- 10
The kit replaces all the capacitors in the machine as an upgrade. I'll have them check the pot before I take it back.
