Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Dec 2006
    Central Iowa
    72
    Default Ring Roller design
    I am getting ready to build a ring roller.
    How does the relationship of distance between the lower wheels affect things?
    What distance are yours?
    Ed
    Salem ,Ohio
    3,974
    Cool
    What are you planning on rolling?. The thicker the metal the farther apart the rollers need to be. I have one roller with the centers of the rollers at 2" and one roller where they are farther apart but adjustable...Bob
    Aug 2006
    Raymore Missouri
    1,925
    Can you be more specific? What size rings and what material size will the rings be made of. Will there be just one material drive wheel? If one drive wheel, let's say, on top and two free rolling wheels below.......the closer the lower wheels are together, the tighter the bend per turn but it will take more grip from the drive wheel or it may just slip and deface the material. Need more info. Ring rollers come in all sizes.
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Dec 2006
    Central Iowa
    72
    I was planning one drive wheel on top and two below style. I was planning on using 3" dia. wheels
    As for material, I was hoping to get alot of bang for my buck.
    One project is 18 to 24" circles out of 1/4 round. But I was hoping to be able to go up to 14 GA 1" sq for just and arc.
    If I make the wheels adjustable, should I make the adjustments on a 1" schedule? From 4" centers to 6 or 8" centers?
    Thanks for the input...you know the six P's rule.
    Later
    Ed
    Apr 2008
    171
    i bought two one from ebay witch does up to 2"x3/8
    it was around $150 and one from HF for $70 and does
    1"x3/16 and 1/4 round use 1/4 round to make
    wine racks
    Dec 2006
    Central Iowa
    72
    Yeah I bought the HF one and it just scars the rod up and doesn't seem to work all that well. So I thought I'd buid one.
    Nice verdigris on the winerack....I assume it's iron. What did you use to color it?
    Ed,
    Here's a link to an arch roller I specifically built to arch 14 and 16 gauge 1" square tubing for ornamental railing, fencing, and gate work. The bottom 2 rollers can be adjusted from 14" to 26" apart. I'm going to add some additional slots that allow me to adjust them closer than 14" when I get time. I've been using it only for arches, and it works really well.
    Mark
    http://www.shopfloortalk.com/forums/...ad.php?t=17295
    Sep 2008
    9
    Here's another example similar of a shop-built roll bender:
    http://bullfire.net/Roll_Bender/WP_Roll_Bender.html
    Dec 2006
    Central Iowa
    72
    Thanks Mark & Ed H. Both are very smooth tools. I doubt mine will be that slick.
    That was pretty much my toughts for the side plates to be adjustable.
    Mark how much closer than 14" are you going to go?
    Ed H, what are the adjustment distances on yours?
    I was thinking I'd start with the first adjustment at about 5" with 3" wheels. And go about every 2.5".
    Thanks for the great input guys.
    Later
    Ed
    Ed H, that's a pretty slick roller you've got. Similar design to what I built.
    Ed, The drive wheel on mine is 4" and the bottom rollers are 1.5". TO do some tighter radius arches, I think I can get the bottom rollers down to 7-8" apart.
    Mark
