Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: bad ratio
    Nov 2007
    dallas tx
    325
    no no no you run and grab the caulking gun and set the trigger to pulse ,and let er rip
    give me a call ,and ill come over and show you how to do it
    my daddy always said i was IRONHEADED....
    feel free to P/M me
    Mar 2007
    Oahu, Hawaii
    2,469
    Quote Originally Posted by welderman23 View Post
    I don't have the money you do!!!!! I just have the $20 gun.....no pulse
    I'm not late...
    I'm just on Hawaiian Time
    Jan 2008
    VA
    298
    Quote Originally Posted by Bert View Post
    Easy to make a home made pulser for the caulk gun.
    had a railing in a healthclub break. Came to reweld the failed corner and found that it was only tacked up only where the metal met. I say where as the pipes were cut flat and sort of fishmouthed a little with a grinder. then large amounts of latex caulk were gobbed on and smoothed out before everything was painted. Looked good but you could kick a railing pipe and an end would break free.
    Weekend wannab racer with some welders.
  4. #14
    Mar 2007
    Oahu, Hawaii
    2,469
    Quote Originally Posted by Vicegrip View Post
    wow! Look at the rest of the railing, find all the "welds" and you got yourself a good job to make that thing safe!!!!!!!!!!
    I'm not late...
