Results 1 to 10 of 11
    May 2008
    Belle Plaine Iowa
    270
    Default Casters for table?
    Whats the best and worst casters to put under my table legs? Steel, poly, rubber, air or hard?
    Im building 3 tables and want them all the same height and capacity. Saw some today at Harbor Freight that looked like good wheels but cheesy brackets.
    Help me out. I only want to do this once.
    Miller AC/DC Thunderbolt 225
    Miller 180 w/Autoset
    Old cutting torch on LPG
    May 2007
    Grande Prairie, Alberta Canada
    729
    The rolling surface of the wheel - Steel or Poly - depends on the specifics of your application.
    I would stay away from pneumatic tires as they are not really designed for this application, and will lose air "sitting" which will alter stability and height.
    Best of luck.
    Later,
    Jason
    Professional Spark Generator by Trade.
    May 2008
    Belle Plaine Iowa
    270
    Probably hard surface like garage or driveway. I didnt like the idea of air tires due to hot metal ***** rolling around on the floor. I also dont want my table to "bounce" when Im wailing away with a hammer doing destructive testing....
    Nov 2005
    130
    I like hard rubber casters.
    They roll over small debris better than steel.
    Also the larger the better, easier to roll.
    Casters on sale -
    http://www.northerntool.com/webapp/w...0&N=762991+120
    Nov 2005
    130
    Oh yeah -
    Check Enco monthly sales flyer.
    Usually FREE shipping > $50. with code.
    Jun 2007
    22
    A summary of my experience:
    Pneumatic will go flat eventually. Murphy suggests it will be flat when you want to move it
    Steel will hold the most weight, will not flat spot, requires a clean rolling surface.
    Non-steel has "anti steel" properties. They usually hold less weight - but may hold "enough" weight for your application. They may flat spot but that depends on what kind of caster material and how much weight they are holding up. And because they are "softer" than steel are more tollerant of stuff on the rolling surface.
    As large a diameter as practical.
    In general I have found steel to have the most load capacity per caster dollar and use the "clean rolling surface" as an incentive to clean up the floor more often than I would without the incentive.
    An alternative design I have used is casters as "transportation only" and have adjustable pads that I lower when I get the table to where I am going. That way the table legs can be adjusted to take into account the variances of the floor and my need to make the table level or the same height as something else. It seems to provide a more stable platform than a table on wheels - even with good wheel brakes. And given that the wheels are simply for movement allows me to use a type that I would not have choosen if they were the primary table support.
    Baldwin, NY
    275
    Quote Originally Posted by arvidj View Post
    I agree, I have 4 1000 lb steel catsers from northern, 15 bucks ea at the time and only use them for tranport. The table is supported by 4 1" bolts with 4" plates. It weighs 2000+ lbs empty so I was worried about anything but steel wheels... Plus being able to level it anywhere is great.
    Voigt Precision Welding, Inc.
    Miller Dynasty 200 DX, Miller Syncrowave 250, MillerMatic 252, Hypertherm Powermax 45, Auto Arc Trailpower 8000,272+187 lb Peter Wright anvil, 120 lb Fisher-norris, and more! Buffalo drill press, Grizzly Horiz. Bandsaw, Edwards shear, Barth Shear, bantam mechanical ironworker, Hopkins fly press, Doall Bandsaw, brown and sharpe surface grinder.
    2007 Silverado 2500HD (tow vehicle)
    2000 Camaro SS (Race car)
    May 2008
    Belle Plaine Iowa
    270
    My table wont weigh anywhere near a ton. Ive thought about moving it like a wheel barrow with fixed casters only on one end and pull out handles.
    Ive decided on 3 tables. 2, 2X2 and one 2X4 all the same height to make holders for long pipe etc.
    Jul 2007
    Lancaster, Pa
    431
    My table is kinda small, 2' X 4' but rather than put wheels on mine. I just use the pallet jack to move it around. However I did make plow dollys to move our plows around the shop on a concrete floor. I used 4 - 750lb rated polyurethane over steel wheels, 4" x 2" for each dolly. The plows weigh a little over a ton and the wheels work perfect. They will go over fine dirt but if there is a lot of debris, it needs to be cleaned up.
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
    Jan 2009
    Oregon
    17
    Default Pic's of table caster setup ?
    ARVIDJ, is there any way you could post pics of your table casters, it sounds like the perfect solution but I'm having a hard time picturing it ? Thanks
