Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 71
  1. #41
    Dec 2012
    Sweetwater, TX
    201
    Kevin,
    Here are some pictures of the welder I need information on. I will have to replace the cord end, so I will need to open it up and while I am doing that I can verify it was the correct wired connections if I had a wiring diagram/manual.
  2. #42
    Mar 2013
    9
    Default Airco EasyArc AC/DC 250 & supply wire to outlet
    Quote Originally Posted by kbeatty View Post
    Kevin
    Would you mind checking another machine cross reference?
    I purchased an Airco EasyArc AC/DC 250, Serial # MH402092, Stock Number 1341 0280 but I cannot find any documentation for it anywhere. I am hoping it is also a Miller product but I fear it may not be because the serial number seems to be in a slightly different format than what the lucky others have posted!
    Any help will be greatly appreciated.
    I have searched the Internet pretty thoroughly hoping to find a manual or at least some information about the maker and age of my welder.
    Thanks,
    Kevin
    If anybody can help me until I locate a manual I will be very grateful. I need to know what kind / size wire I need to use to wire from my 200 amp service to my 220 volt outlet. The outlet will be approx 35 feet from the service.
    My best guess is #6 AWG but that may be over buying. I really do not wish to guess about something this important! Again, any help is appreciated.
    Kevin
  3. #43
    Apr 2010
    279
    Kevin, what size breaker do you plan to use?
  4. #44
    Mar 2013
    9
    Quote Originally Posted by USMCPOP View Post
    50 Amp
  5. #45
    Apr 2010
    279
  6. #46
    Dec 2012
    Sweetwater, TX
    201
    50 Amp
    If your not turning the welder up that would be fine probably... I'll let you know when I try it on my Easy Arc. I also have to change the input wire on mine and I will use 6AWG, but I'm only going to go maybe 6-10ft.
    It states on the sticker 100Amps for 230V with the rating at 250A 50% duty cycle, so it will be possible to trip the 50A breaker if the welder is turned up.
    At least that is my guess. I will find out for sure when I try it on my shops 50A breaker after I change the cable and connector on mine.
  7. #47
    Mar 2013
    9
    Thank you, USMCPOP. I will study the information on these shortcuts. I appreciate your help.
    Kevin
  8. #48
    Mar 2013
    9
    Quote Originally Posted by clint738 View Post
    Thanks Clint738. I look forward to hearing how your tests work out. I have not done any of the wiring (obviously) so I can go with a larger breaker or wire if the situation demands it.
  9. #49
    Appleton, WI
    389
    Kevin,
    With the serial number you provided I figured that is was not a Milller unit but I went through my cross reference chart and had another tech double check his as well to confirm. The unit you have there was not made by Miller Electric.
    Sorry I could not be of more assistance with this.
    Kevin Schuh
    Service Technician
    Miller Electric Mfg. Co.
  10. #50
    Apr 2010
    279
    It may be that the Easy Arc was made by Mid-States Manufacturing. They had a MST-160 which people have said is just like the AIRCO Tri-Arc 160. Same polarity/process switch handle as the Easy Arc. I believe they were bought by AIRCO. Maybe ESAB has a manual.
