Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 75
  1. #21
    Dec 2011
    i ahve a 250 amp heiliweder i'm looking for a manuel and also want to find a mig to attach to it. It looks like the this one below but it says it a airco but I was told its made by miller.
    http://www.ebay.com/itm/NICE-AIRCO-2...-/160663632281
  2. #22
    Nov 2003
    3,433
    Default 1980 Dialarc HF...??
    looks like a Dialarc HF..... maybe HF-P??
    Manual.... see how this stacks up...
    http://www.millerwelds.com/om/o315g_mil.pdf
    My Blue Stuff:
    Dynasty 350DX Tigrunner
  3. #23
    Dec 2011
    Default thanks
    that's it thanks now to find a mig box that works with it
  4. #24
    Nov 2003
    3,433
    that is a "Drooper" (constant current) type power supply.. and not really intended to run mig... ideally you will have a "constant votage" power supply to run MIG....
    but you can do MIG with a VS (voltage sensing) feeder.... with this type of power supply..
    http://www.millerwelds.com/products/...se_x-treme_vs/
    look at the Voltage Sensing section.. in the Miller feeders..
    http://www.millerwelds.com/products/wire_feeders/
    Lincoln and others make voltage sensing feeders as well as Miller....
    My Blue Stuff:
  5. #25
    Mar 2010
    Ceres, California
    358
    But for the price of one of those feeders you can buy a small mig welder that will weld mig wire a lot better.
    A VS feeder on a CC welder will only weld large flux core wire fair. 035 MIG wire not well at all.
    Glenn 300 amp stick
    Millermatic 35
    L-tec plasma
  6. #26
    Default Heliwelder manual
    A friend has a much-loved:
    Code:
    250 Ampere AC/DC Heliwelder
    Airco 0475
    1341-0178
    on the Orange/white case.
    and needs a manual, hopefully with schematics. I understand it may have been made by Midstates, Miller, or ESAB.
    Suggestions?
  7. #27
    8,109
    ESAB, and you while you may find a wiring diagram, actual board schematics you won't find anywhere....
  8. #28
    Thanks....
    Any print would help.
  9. #29
    250 Ampere AC/DC Heliwelder Airco 0475 1341-0178
    ESAB admits paternity but says they have no documentation left; they sent it to someone in California who has recently stopped supporting such.
    Any suggestions for someone else; perhaps a repair facility in the Cleveland/Pittsburgh area? [Such may cost more than the unit is worth, I fear...]
  10. #30
    Dec 2012
    Default Airco 300 amp Yellow Jacket
    I too have started working on a Yellow Jacket 300 amp and would like any wiring sch. or manuals helpful for a rebuild. Model # 3DDG-LDB-B Serial #38186M9
    David
